from scratch homemade loader
   / from scratch homemade loader #1
bal0123
Purcell, Oklahoma the middle of no where
Yanmar 2210, and 2, 425 John deere lawn tractors
Let me say thank you all, I finished my homemade loader from some srap material and some I bought from the steel yard. I did not have a plan just drew some pics up and figured all the measurements out with a sharp eye. I bought my two boom lift cylinders from Northerntool, I tried to use a cylinder I got out of the trash at work for the dump cylinder but there was just not enough stroke. It was a steering cylinder off a Dynapack compactor. that is the black one in the photos. I ended up ordering another cylinder from Northerntool for the dump. All my cylinders are the same 16" of stroke and are all 2.5" barrels and 1 3/8" rods. Seem to work very well. I put this loader on one of my two John Deere 425 lawn tractors that already had hydraulic system all I did was added the proper hoses and fittings and the loader itself. I lifted a trencher out of the bed of my pickup and have moved several yds of dirt and compost with it since I finished and MAN I will tell you it is the best feeling in the world. I checked out the cad loaders and just seemed I could build one myself for half the money. I built this loader for a little over 600 dollars and it has been money well spent. Hope yall like the pics. Chris:):)
   / from scratch homemade loader #2
Awesome job. One of the reasons I think that most of us have equipment like this is the enjoyment of doing things. I cannot think of a more satisfying task than getting something done with equipment that you produced yourself.
Enough talk, when are you going to have the BH done?
Hey Paul, Thanks for the nice comment I like your ride there. I have been doing some thinking on the BH but I think I will build a loader for my yanmar now. I am just not forsure about all the weight on the rear transfer case of the lawn tractor. A backhoe is heavy with a lot of weight and don't want to break a axel or anything like that. Have you had any problems with yours. John Deere is darn proud of there parts and even though I work at a dealership I still can't afford most of the parts that go on my 425's and that is at cost.
   / from scratch homemade loader #4
I admire your ability! No plans? You just made it happen! That's really neat. I'll bet you had one heck of a grin on when you put it to work. Good going and thanks for sharing.
   / from scratch homemade loader #5
Great job Chris!! Some of the best creations I've ever seen were built without plans. Let's face it, sometimes when we start a project, we're not sure how all of the details are going to work out. Sometimes we have to....uh.....modify things a little bit.:rolleyes:
Keep up the good work!
   / from scratch homemade loader #6
Excellent work Chris! Looking forward to seeing more fabrication from you in the future.
   / from scratch homemade loader #7
It's green.... it has to work ! I like the one bucket ram theory. Small loaders don't really need two of them based on the capacity.
How is the movement response with the size cylinders you went with ? I'm collecting material for my loader project but haven't sized rams as of yet. There is a fine line between capacity and the right size rams for the most efficient rate of movement. A small loader can be a very useful asset.
Thanks for the pictures & information.
   / from scratch homemade loader #8
Too bad about the green thing...but otherwise looks good!!
LOL! Bobodu about the green thing.
Joes427vette,, the cylinders I used I just picked them out of random looking at the size of rod stroke and diameter, and the length from pin to pin fully extended and fully retracted. I got the measurements out of the Northerntool catalog and then took a piece of pipe and welded basically like pin holes or eyelets to each end. Made two of them, one the full extracted length of what clyinders measurement was and one in the retracted position and those pieces of pipe were what I did my measuring from and it all seemed to work out. As far as performance goes boom raise is about 10 sec. and boom down is a little faster at about 6 sec. I did the single dump cylinder just do to cutting costs. If it did not work I would have gone back and put on a second cylinder but it works just fine. I did have to weld some stops onto the bottom of the bucket were the boom attaches to due to the little to long of travel of the bucket dump cylinder. It would extend all the way out and then go make the bucket roll back under the boom when dumping and was not able to retract the cylinder because it was wanting to go the opposite direction it was really meant to go. The welded bucket stop solved that problem. Thanks to all the nice comments and I look forward to seeing more of yalls inventions and gadgets and whatnots. LOL
   / from scratch homemade loader #10
I cannot take credit for the image I posted .... I was simply trying to get you to keep building! The good news is that I use my FEL 10x as much as the BH. Nice job again ....
   / from scratch homemade loader #11
Chris is it my imagination or from the prepainted version to the painted version did you ad some braces going from the front of the tractor back to the uprights on the loader ?
Gemini5362, Your correct I did add these braces after I took the first pics. To be honest with you. If you look real close at the unpainted version compared to the painted version they are two different booms. The unpainted version I started with first, made the boom out of 2" X 2" X 16 gauge square tubing. Trying to cut cost U know I figured that would be strong enough for the boom, after I built the bucket I got to thinking it prolly was not stought enough so I wrapped the 16 gauge tubing with 1/4 inch strapping the entire boom. Well then it looked like crap cause I ain't the best welder, Using a lincoln cracker box welder. I have no training in welding, just self taught myself, trile and error. So then decided to buy some 2" X 2" X 3/16" square tubing and build the second boom and it was plenty heavy and works great. I have worked the heck out of this little tractor and have had no welds brake yet. I do need to add some more weight to the rear end, it tends to spin the tires a little when loader is loaded. Fixing to put some tire chains on the rear tires this weekend. Maybe that will help with traction. Well thanks for the looking and noticing the detail.
   / from scratch homemade loader #13
Chris,
Good job. I have a JD 425 as well and am looking into building my own loader for my tractor. Would you have the plan available for your loader?
Kevin
   / from scratch homemade loader #14
NICE Work!
   / from scratch homemade loader #15
Nice work Chris.
Below is link to pics of my homemade FEL. I cheated and used autocad to help with the design. I am working on my forks now.
   / from scratch homemade loader #16
Nice work Chris.
That's a darn nice loader you made for your BX. I don't consider using AutoCAD cheating as I use it for some of my projects and definitely would if I were building a loader.
   / from scratch homemade loader #17
Nice build, did you have any trouble getting all of the pins and bushings sqare to the loader? The last time I tried a build like this, the few degrees here - few degrees there cause a lot of binding popping and cracking (obviously my self taught welding course was probaby not as good as yours!).
Looks great man, nice to see somebody avoid the curse of the $3k loader on a $3k tractor. Keep it up.
   / from scratch homemade loader #18
That really is a nice loader! I'm on the fence right now on deciding to upgrade to a 425, 445, or 455. I'm considering a homebuilt loader as well. About how long did it take you to build everything? How long does it take to attach and detach the it?
   / from scratch homemade loader #19
Great job on the loader. I had a man tell me just today a loader had to be bought for a tracor that one of any usefulness couldnt be made. I just laughed
Im about to make a loader for dads newly aquired 991 Pasquali Its gonna be fun because the thing is short and squat and articultated. I dont know how high to make it lift because of its size.
Archaic when I build anything like that I make them in pairs. What I do Ill cut one out then dress it like I like it then make the other one on top of it. One things with pins and bushings Ill make the parts and hold them together with a longer pin or bolt the same size as the bores to hold them togeter to compare and measure them and it works pretty good that way.
   / from scratch homemade loader #20
Nice job! I really like the quick attach system you made for your bucket.
-Mike
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
New Holland Basket Rake (A56438)
New Holland Basket...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
154 (A52708)
154 (A52708)
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
