How long can diesel be stored?
   / How long can diesel be stored? #22
I just recently checked the tank for water by using water indicator grease.
(it's yellow and turns red when contacting water) I was expecting at least an inch or two of water. NOTHING.
Can i ask where you buy such stuff? i'd like to get some. sounds like a very useful test.
Theo
   / How long can diesel be stored? #23
Theo
I've called all over and googled til I am blue in the face. no one i've called seems to have heard of water indicator grease or anything similar. anyone know of an online source, manufacturer or brand name? thanks.
Theo
   / How long can diesel be stored? #24
I was interested, too.... here's what I've found..using COPERNIC and searching on " diesel water indicator test"
http://www.kaagat.com/2008 Johnson Test Papers Catalogue.pdf
says: Water Finder Paper provide a quick and reliable method to detect water in solutions such as petrol, diesel and other non-miscible liquids. The paper is simply attached to a dipstick and if water is present in the fuel it will remove the chemical surface of the test paper leaving only the white backing paper behind, providing a very clear indication. Apart from the detection of water in oil, petrol or diesel, water finder papers are suitable to work with other non-miscible solutions. Any suspended drops of water are shown as white spots.
I didn't locate cost or where to buy.
this seems like the cat's meow for keeping your diesel clean:
Automatied Fuel Polishing and Filtration System
   / How long can diesel be stored? #25
Theo
Kolor Kut is what we use.
Kolor Kut Paste
I think we use to use one called sargel or something similar.
   / How long can diesel be stored? #26
Thank you texasjohn and alanb. now i have some names to look for. very helpful.
Theo
   / How long can diesel be stored? #27
You and me both. and here is the part that confuses me more than anything else. suppose you buy a 250 gallon tank and have it filled on day one. then you use 125 gallons the first year and have it refilled. then you use 125 gallons the second year and have it refilled again.
question: after that second refill at 2 years and one day after buying the tank, how the heck old is your diesel fuel??????
Theo
Seems like assuming complete mixing you have 62.5 gal of two year old diesel mixed with 62.5 gal of one year old and 125 gallons of fresh. Is this like a high school quiz? LOL
   / How long can diesel be stored? #28
Not exactly sure of the spelling but Sargel is popular among gas stations and marinas for water dectection. It's a grey/white paste that turns violet when water is present.
   / How long can diesel be stored? #30
SAR-GEL is what I have at home. Alway's seems to work well for me
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
Brock 5 Ton Feed/Grain Tank (A55218)
Brock 5 Ton...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
