Anyone use Warren hydraulic oil
   / Anyone use Warren hydraulic oil #21
No, I don't partially drain. I am just talking about a top off of fluids, small leaks, what you lose as you connect and disconnect hyd lines, etc. Most medium to large size tractors are going to take, as you pointed out, a lot more oil than 5 gallons. Hey, its all good...not sure it really makes a difference. I knew a guy that had a 1086 and he put just about any kind of oil in it he could get his hands on, the thing is still running.
   / Anyone use Warren hydraulic oil #22
As the old machines prove.. in most cases.. usually any oil is better than no oil.
soundguy
   / Anyone use Warren hydraulic oil #23
Warren Distribution (since 1922) is based in Omaha, Nebraska and has been Tractor Supply Company's supplier of lubricant products since 1997. As a large, privately owned independent oil company, Warren blends and packages private-label oils for major brands in the market, including retailers, the Department of the Defense and other agricultural brands, including Traveller.
Warren purchases the highest-quality severely hydrotreated base oils available from the world's major refiners and combines them with the most technologically advanced additive systems, resulting in finished lubricants that meet or exceed OEM requirements. Warren Distribution is fully licensed and approved by the American Petroleum Institute
TSC fluids are very good and at a price you do not mind changing fluids often. KennyV.
   / Anyone use Warren hydraulic oil #24
Thanks Kenny for the info. It only makes me more confident that using the TSC ,Traveller Premium UTF, for my Kioti is a good choice. Now when are they going to offer synthetic engine and hydro oils?
In the mean time I will continue to use Shell Rotella Diesel Syn from TSC or Walmart(whichever has best price) in the Kioti. In my car I use wally world synthetic 10w30, 3.3 Chrysler now has over 211,000, doesn't burn a drop and there is Zero sludge under the valve cover, not bad for "cheap oil!!!" Trans I have it flushed & filled with BG synthetic products every 100k, still like new, now if I could stop the rust.
   / Anyone use Warren hydraulic oil #25
Didn't I see some supertech syn oil at walmart.. I believe warren makes oil for walmart as well.. at least I think i saw that in connection with walmart's supertech UTF oil... ( which is what i use.. )
soundguy
   / Anyone use Warren hydraulic oil #26
Well I wonder if I have the wrong Warren OIL Company as I do not se Neb. on the address on this letter from them ?
   / Anyone use Warren hydraulic oil #28
Thanks Kenny, I am having a devil of a time tracking down a spec sheet for Harvest H/T oil.
I came up zip. Have any info on them. That Warren stuff looks real good to me.
But out of the two stores in my area it is either Travelers or Harvest.
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
Electric Mobility Scooter (A51694)
Electric Mobility...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
