Flat free tires for carts
/ Flat free tires for carts #1
MrWoodChips
Well, I made a mistake the other day. Our tow behind cart was always losing air in the tires, so rather than tubing them, I bought new flat free tires from Marathon. Not in itself a bad thing to do. I purposely got tires that were rated for more of a load than the originals were. We get a lot of use from that little cart, so it seemed worth it.
So one day I had to move some rock about a mile down the road. The tires had a claimed rating of 500 pounds apiece, so 700 pounds of rock seemed not too much to pull with the tractor. The flaw in my thinking was the hot, sunny day I did it on. Half way down the road (asphalt, and hot from the sun - 83 degrees in the shade that day) I looked back at the tires and noticed they seemed loose on the rims, as if they had expanded from the heat. Thinking I should watch that and take it easy, I drove on for only another 50 feet. One of my brand new tires had just rolled off the rim. I felt it, and it was really soft. The load on them had probably added internal friction, kneading them to be way too hot.
I returned with alternative transportation to rescue the trailer, but now I was stuck with a rim and a tire, sadly disconnected. There was a small tear in the tire, created when it came off the rim. Once the tire cooled down, it shrunk in size and stiffened up dramatically. There was no way I could get it back on the rim. So I wondered how they did it in the factory. Probably use microwave heating to soften and expand it, then I'd push the tire onto a mandrel, and slide it right onto the rim. Since my wife might object to this use of our oven, I thought some more.
An easy solution came to me eventually. A bath in our tub with the hottest water I could deliver warmed the tire back up, though probably not quite as soft as it was the other day. It was at least now malleable again. I measured the inside diameter of the donut, and it had grown by nearly a half inch. I was debating if I'd need to use boiling water, but this seemed like it might work.
A big screwdriver and I now were able to lever it back on the rim. Once I had it on, a little polyurethane glue seemed the right fix for the minor tear in the poly tire.
Lesson learned - don't overheat flat free tires. But if you do, they can be reheated. ;)
John
/ Flat free tires for carts #2
Wow! Sorry, but those tires don't sound very good to me. I'd be taking them back for a refund. They shouldn't do that, even if the air temp is over 100. How fast were you going? Had you thought about just getting regular tires foam filled? Or buying multi-ply and then use them with inner tubes?
Yes. I was disappointed in them. As long as I stay around the yard, they are fine. I had thought about the other options, but these seemed perfect. Not too much more than a regular tire, especially since I was going to to replace the rims. (The old rims were beat up, possibly why they were leaking air.) Having a regular tire foam filled is not cheap from what I'd heard. Tubes in a multi-ply tire would probably have been the best solution in hindsight.
I was not speeding, since my tractor only goes up to 8 miles an hour at max speed. I was pretty much maxed out on the road, but even so I'd not call 8 MPH "fast".
I'm planning on keeping these tires, I'll just stick within their limits. At least they won't go flat on me.
John
2018 Chevrolet Equinox AWD SUV (A59231)
2018 Chevrolet...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
CFG Industrail MX15RX (A53317)
CFG Industrail...
King Kutter II Tiller for sale.
King Kutter II...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2014 International WorkStar 7400 Service Truck, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
