Who has disabled the safety device called
   / Who has disabled the safety device called #21
Where does it stop? After it's determined that you need a yearly proficiency test to operate a tractor?
j (grumpy this morning) b
Shhhh! Don't give them any ideas!!!
They are trying to get a law passed here that electrical work can only be done by licensed union workers -- after a 7 year apprenticeship! Criminy, 7 year apprenticeship to replace an outlet? Tractors are far more dangerous, that would probably be a 15 year apprenticeship!:eek:
   / Who has disabled the safety device called #22
Bought my B2410 used and not one safety shutoff is enabled, not sure how or why, never looked, but even the mid mower would keep turning on dismount if I didn't pop out the PTO.
Hey...one great thing about hydro is you can move the tractor when off it by pushing on the pedal with your hand! Just don't stand in front of the tires. Actually this would be highly frowned on by the safety police but it sure comes in handy quite often.
   / Who has disabled the safety device called #23
the biggest piece of safety equipment is your brain.
This comment may have to be taken with a grain of salt. In my case, same as for probably many others there is a near perfect brain [ read unused ] sitting between the ears.:):)
   / Who has disabled the safety device called #24
A cable tie and some electrical tape took care of that PITA on both my JD2520 and L130.
I take full responsibility for my own actions. More people should.
   / Who has disabled the safety device called #25
My seat switch has a pushbutton over-ride. It requires a constant push. I needed the occasional ability to stand up to see while in motion. Yet if something happens the tractor will still die as designed. The deere's have a PTO override for fixed operation.
   / Who has disabled the safety device called #27
Tractors are no longer designed by engineers. Lawyers and the courts design them now because of law suits and injuries. I am retired military and I have been in a couple of conflicts, I know what living on the edge is all about. I plan on keeping all my safety's intact.
   / Who has disabled the safety device called #28
If the union want's to pay me for those 15 years of mowing, dirt moving, log hauling, tilling, plowing, planting, ect .....
If not ....
You know the old saying about what you call 200 lawyers at the bottom of the ocean? Well add about 3 zeros, then double it and put in that many politicians too!
If government was 1/50th it's current size it would still be 10x larger than it was in 1900. Think about it.
jb
   / Who has disabled the safety device called #29
My montana did not come with a safety seat interlock. I think the only actual safeties on it are:
1. Wont start with out the clutch pushed in
2. Wont start with the PTO switch turned on.
Other than that you can get out of the seat and it wont die. Use implements in reverse or anything else the tractor can do.
   / Who has disabled the safety device called #30
Because your Montana was built on an AG model of tractor...mimimal safety intrusions...:D
lots of CUTS are being bought by people who have NEVER even seen PICTURES of a farm...:D
2015 Toyota Prius Hatchback Sedan (A50324)
2015 Toyota Prius...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2013 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2013 FREIGHTLINER...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
Kubota ZG327 (A50120)
