Well being drilled tomorrow, anything I should look for?
   / Well being drilled tomorrow, anything I should look for? #1
Tororider
SE Michigan
JD 4310
We are having the well drilled out at the farm tomorrow. We have been talking with this guy for a long time and I have a good feeling about him. I will probably be out there for most of the time he is drilling, is there anything I should be asking him to do? Thanks
By the way, it will be really nice to have a hose out there to wash the tractor and not have to drive it into town to the quarter car wash, or to have to tote water out there in the back of the pickup truck to water the trees.
   / Well being drilled tomorrow, anything I should look for? #2
Make sure they cart away their trash (concrete bags, ect). They like to bury it on your property.
Take lots of pictures.
Ron
   / Well being drilled tomorrow, anything I should look for? #3
I'd look for water for a start. But really make sure he uses a pump rated for the lift required , if not you will get only minimal pressure.
Yeah, we are oversizing the pump. Want to have the ability to use it for more applications later on.
   / Well being drilled tomorrow, anything I should look for? #5
We used a guy with a pounder, he was careful to ask where we wanted the "juice" to go, it is pulverized rock mixed with water and sets up harder than concrete. Hope you hit lots of water and not too deep.
   / Well being drilled tomorrow, anything I should look for? #6
I think you should look for, naw, hope and pray for...OIL! Forget the water!
You want some Texas Tea! Wouldn't that be a hoot..."say sonny, what's that black stuff???"
   / Well being drilled tomorrow, anything I should look for? #7
bring your ear plugs.
   / Well being drilled tomorrow, anything I should look for? #8
Good luck with the new well . & I hope You take pics .
We have 2 cased wells at this time . & Thinking about putting a 3rd on in & having it drilled , the Existing 2 are really bad water . I Had a Quote of 3500 dollars to drill one 60 to 100 foot. Just curious if thats inline with most ?
Theres no rock or clay here so its really easy to drill I would think . I Just cant seem to get one near that deep by hand Because it starts going crooked after 30 feet or so .
CB
   / Well being drilled tomorrow, anything I should look for? #9
You will surely enjoy your well. A well is the biggest thing you can do to completely change the way you look at a place. Water is a huge event when developing your home in the country. Once you have water, things start to take shape very quickly.
There is a new house being built about 1/4 mile down the road from me. Two weeks ago, a well driller showed up to put in the well. He only brought 360' of drill pipe. My well is 386' deep and we are about 50' below where he is drilling. Several of us went to talk to the driller and let him know where our water was located. My wife's place has a well at 420' and most of the rest of us are around 380'.
When the driller used up all his pipe and hadn't hit good water, he had to go to a competitor and borrow a couple more sections of drill pipe. At 380', he found good water, but about the time he found it, he got a stuck pipe. It seems his drill pipe stuck deep in the hole. He ended up twisting off the drill pipe. So this guy had taken 5 days to make a mess and got fired by the contractoir.
On Friday of last week, another driller showed up and had the well drilled in less than a day. So now, they have two wells about 25' apart. One has a stuck pipe and I think nasty water is probably going to seep out the walls of the unfinished well and get into the water table where the new well is located. I hope not, but most wells in this area have very hard water around 260' and good water down near 400'. A good seal around the casing is needed to keep hard water from getting down in the good water's pool. That's what my driller told me, and my water has been terrific, so I have no reason to doubt him.
Good luck with your well.
Well, he had an emergency this morning and wasn't able to make it out, so first thing tomorrow morning.
Now we just need a septic so we can put the bathroom in the barn, so we can put in a shower to clean up after "playing" out there.
2015 TEXAS PRIDE  GOOSENECK (A52472)
2015 TEXAS PRIDE...
John Deere 310A Loader Backhoe (A52384)
John Deere 310A...
2015 FREIGHTLINER CASCADIA (A52472)
2015 FREIGHTLINER...
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
2015 PJ TRAILER  16 TANDEM AXLE UTILITY TRAILER (A52472)
2015 PJ TRAILER...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
