Trees for wetlands
   / Trees for wetlands #21
Thanks a lot studor! Can you elaborate a little on the disking or shallow ploughing, not to sure I understand what you mean, thanks!
Just make sure you don't confuse Tamarack (Easter larch) with Tamarisk (salt cedar). Here in CA tamarisk is an invasive riparian plant that will crowd out native species like cottonwood.
   / Trees for wetlands #22
Hi each county forester or county conservation office will have the plants you need.
I am enrolling in CRP. A big section is swampy almost year long, the other when it rains.
the trees i am using are
swamp white oak,
pin oak
the oaks are for the more wet areas,
then i am going to use
sugar maple,
shagbark hickory
black walnut
butternut
these are going in the sometimes gets swampy area.
check out
scholar.lib.vt.edu/theses/available/etd-041399-091320/unrestricted/klapproth2.pdf
its not the chart i have, the chart i have lists the tree, wildlife value, moisture preference, and growth rate, along with natural habitat and notes on the tree. if there is any tree you are interested in let me know i can look it up and let you know if it works in wet soils.
good luck
swamp white oak,
pin oak
sugar maple,
shagbark hickory
black walnut
butternut
check out
good luck
Thanks! I am interested in all these trees w/ a fast growth rate. Also any that reproduce in large numbers. You said you are enrolling in CRP, what exactly is this? Thanks again
   / Trees for wetlands #24
At the farm Black Walnuts have sprung up as volunteers along the creek and grassy waterway. Pretty easy the squirrels do all the work. :D Some of the ones that I can keep track of went to 4-6 inches in 15 years. May eventually have some commercial value if the farm doesn't fall to development first.
Chris
   / Trees for wetlands #25
If you wanted to plant from seed it will soon be time to gather fallen walnuts but you got to beat the squirrels to them. :D Also they seem to suppress the weeds growing under them for what it is worth.
Chris
   / Trees for wetlands #26
In by Arborist business when someone wanted a thirsty tree, I'd plant a River Birch (Niger Birch). They are very thirsty trees and they are not bothered by bronze birch borer, They are attractive trees with a light brown exfoliating bark. All in all a great tree for wet areas.
I've planted them in places where the hole you dig fills with water as you dig it and they have done very well.
Thanks toad hill! I will look into seeing if I can get some of these as well.
   / Trees for wetlands #28
CRP--is a concervation reserve program. Its a partnership with the usda and state departments of ag. They try to manage soil run off and rebuild forests.
Take my situation, I am enrolling 1.33 acrs of land. This land is swampy in one corner and field like in the other. I am tried of paying for gas to cut the grass. I am also looking for a way to plant trees to enhance the value of the land.
Crp is going to pay me 50% the cost of the trees and tree tubes plus 50% of the labor to install, they have a cost share formula. Since i am going to do the work myself i will get it paid for. I have two years to plant all the trees and i must manage invasive weeds. (i can spray them, and they will cost share the labor and price of the spray). I signed a 15year lease with them and it works out to over $100 an acre, depending on your soil type.
You must have 70% survival rate.
I will be planting about 170 trees, and 50 shrubs.
Like i said
the swamp white oak med grower, low moist forests and wooded swamps habitat
pin oak medium grower, low mosit or seasonally wet woods or swamps
black walnut, fast grower, open woods and meadows
shagbark hickory, slow grower, low moist woods and slopes (also a bat habitat in the bark)
butternut, fast/med grower, lowland woods
sugar maple, med mosit woods wooded slopes,
and my last
can be apples. i can only have a max of 6 apple trees. I have contacted a guy about grafting apples on the approprait rootstock so they will survive in the area.
My biggest concern is the deer, the deer eat everything, not sure if i can fence it all in. the tubes protect it against the voles, which eat the bark and cause winter kill. You must also have a min of 7 varities of trees.
shrubs a min of three
i will pick highbush blueberries,
american cranberrys
and filberts or american hazlenuts.
Its going to be some work putting them in, but over the long run, i will save on work cutting the field, and will bring some much need regeneration to the fields. Once they do start producing seedlings, i can transfer them to the wooded land we own as i cut the beech for firewood.
Its a lot anyother questions just let me know.
   / Trees for wetlands #29
Forgot to say too, black walnuts have a weed supressor in their roots. so you cant plant blueberries near or around them. If you are going to go with them sometimes it takes some planning.
Thanks very much forgeblast! That is very appreciated. I am guessing you went through your state dept. to get set up in this program? This sounds very interesting and exactly like my situation.
2020 JOHN DEERE 332G (A50854)
2020 JOHN DEERE...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
Misc. Commercial Kitchen Equipment (A50860)
Misc. Commercial...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2015 Mitsubishi Mirage DE Hatchback (A48082)
2015 Mitsubishi...
