Injection Timing Help Needed
   / Injection Timing Help Needed #11
You can set timing on most injector pump type diesels by removing all the injector fuel lines from the pump. Rotate the engine in the direction of rotation until you see the exhaust valve on #1 cyl close. Continue rotating the engine until top dead center is reached on the flywheel indicator. Now back the engine up (reverse rotation) about 1/4 turn. Put a little fuel into the top opening of #1 injector pump outlet (where you removed the injector line). Wipe off the excess fuel so the puddle on top of the pump outlet is concave. Very slowly using a pry bar on the fly wheel teeth, one tooth at a time, turn the flywheel in the direction of rotation, all the while watching the fuel puddle in the pump. As soon as the puddle moves the slightest amount, from concave to convex, stop and look at the timing marks. If your timing should be 14 degrees BTDC the flywheel marker should read 14. If it does not than most manufactures use slotted holes in the pump mounting flange to allow you to rotate the pump a little to adjust the timing, much like turning old style distributors.. After moving the pump and retightening it the process must be repeated. You can also do the inverse to rough set the timing. That is, set the flywheel to the proper advance mark and very carefully rotate the entire pump in the mounting until the fuel puddle moves. You must then redo the first process for fine tuning.
Should the puddle not move than you are probably 180 degrees out. The easiest remedy is to remove the pump turn the pump shaft 180 and reinsert and try again.
I have used this method hundreds of time and it has always worked well. It will only work on engines with inline or rotary high pressure unit pumps.
   / Injection Timing Help Needed #13
Not sure what the technical name is, but I call it drip timing on my old Mercedes. After finding the correct timing mark on the pulley I loosen the pump at it's pivot point. I set the idle at 600rpm, establish the coarse pump setting according to the timing mark, and shut off the engine.
Then there's a little device that temporarily replaces the #1 hardline at the injection pump. It's basically just a threaded compression fitting with a short piece of hardline curved into a 180 degree turn. I then start the engine again, verify the idle is still @600, then rotate the pump till I can time 1 drip per second out of that device. Tighten down pump, remove device, replace #1 hardline, job done.
Not that it has anything to do with timing a Chinese tractor, but I thought drip timing deserved a place right alongside puddle timing.
//greg//
Thanks for the info. I'm feeling a lot better about getting this thing going again. Unfortuneatly I won't have time to get back to it until next weekend.
Greg
I was finally able to get back to trying to get this tractor started. Between deaths in the family and travel for work, I haven't had a chance to get to it in almost a month!. I pulled the injection pump rotated the engine through on revolution. I reinstalled the injection pump, bled the lines and cranked it over. It fired and ran beautifully for all of 15-20 seconds then quit. I thought there may still be air in the system so cracked the injector fittings and cranked it over with the compression release locked open. Again it fired and ran for a short period of time. I kept this up for almost 5 hrs last Sunday and the best i could get was about 1 minute before it quit. I checked all of the connections for leaks and i have plenty of flow from the fuel tank. Any ideas or suggestions? I'm getting to the point where i am considering pulling the diesel, welding up a frame and putting a Briggs and Stratton on it.
Thanks
Greg
   / Injection Timing Help Needed #16
I have seen the supply hose to the primary pump on the injector pump collapse inside. they can flow fine but under the suction of the fuel pump, close of and stop the flow.
   / Injection Timing Help Needed #17
There is a check valve on banjo bolt that holds the fuel line to the front of the injector pump,verify that that check valve bolt is in the correct hole.When the pumps come from the factory they put that bolt in the back of the pump just to screw us up I think.If you are looking at the pump there is a fuel line that connects to each side of the pump,if you dont know for sure just switch the bolts (not the lines) so the bolt with the ball check is in the front
Tommy
Affordable Tractor Sales
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
   / Injection Timing Help Needed #18
Good call Tommy. I had forgot about the 5 hours we spent trying to get our first jinma pump replacement to work because of that check valve. As I recall, a characteristic of the check valve on the wrong end is the hand pump would get hard after a few strokes. When correct, the hand pump should be able to circulate fuel continuously.
Thanks
I am going by memory here, but I remember being confused as the check valve on the new pump was not on the same side as the one on the old pump. I won't be able to get to it again until this weekend, but this will be the first thing I check. Just to be sure that i have it in the right place, it should be located on the exit side of the IJ pump, correct?
Thanks
Greg
When I reread Tommy's email i realized he answered my question before i asked it. I can only push the priming pump a few times before it locks up so I believe that this check valvie is my problem.
Thanks again.
Greg
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2018 INTERNATIONAL LT SLEEPER (A54607)
2018 INTERNATIONAL...
1838 (A51248)
1838 (A51248)
