Krone AM 323 S - Checking cutter bar oil
/ Krone AM 323 S - Checking cutter bar oil #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
When do you check the oil in it? I was flipping the blades on mine last night and decided to check the bar oil. It looked low, but how long does one allow for the oil to drip down? SAE 90 oil isn't exactly going to just fall to the bottom. I guess I should have stored it in the up position so I could check this morning.
I guess I can go cut some with it to warm the oil and then check it.
Advice?
D.
/ Krone AM 323 S - Checking cutter bar oil #2
I usally run it for 10 min, then flip it up & check it. By the time I get off the tractor & get the tools for the plug I figure it drained down enough.
I left it up over night. I am going to check it before I cut tonight.
Thanks,
D.
/ Krone AM 323 S - Checking cutter bar oil #4
The oil will come down quite a bit faster than one would think, as long as the weather is warm. I generally just stand it up and check it a couple of minutes later. I check my mine every day before we start cutting.
Mine ended up being 1.5 quarts low. I don't see any leaks, so who knows if it was ever filled correctly. I just got done cutting 100 acres. I figure over the winter I will clean things up. Change all 3 gearboxes oil, put new blades on it, touch up the paint, etc.
Thanks,
D.
/ Krone AM 323 S - Checking cutter bar oil #6
It seems to be the nature of them to vent off a little oil. Mine uses about a 1/2 pint a day. Very hot temps or very dull blades increases oil use. One of my mowers had a bad bar vent and went from the 1/2 pint to using a quart a day.:eek: After it warmed up you could actually see 90W oil dripping out of the vent on the end of the bar. The dealer sent a new vent under warranty and since then no other problems.
We have finished hay up all the hay we are going to do. I have the same plan as you over the winter all fluids will get changed, new blades, and a very good check over.
The manual says check the oil every 100 hours of use. That does not seem often enough to me.
Also, it says change it every 350 hectares which equates to 864 acres. That seems reasonable I guess.
Where is that vent located? I will check mine also.
Also, have you seen any loss of oil in the other 2 boxes?
D.
/ Krone AM 323 S - Checking cutter bar oil #8
The vent is recessed on the very end of the cutter bar. I have never seen any loss of oil from the other boxes yet. My dealer advises checking the cutter bar daily and the others by the book.
I will look for the vent.
What oil are you running in your mower?
D.
/ Krone AM 323 S - Checking cutter bar oil #10
Wal mart 85-140W.
Wal mart 85-140W.
The manual for mine calls for SAE 90. I have wondered if I should a multi-weight.
Are you running a synthetic?
D.
/ Krone AM 323 S - Checking cutter bar oil #12
I checked and the last I bought was straight 90W and when I change the oil out that is what I will most likely use. I have not tried synthetic. The old Vicon mowers I used to use were the same way on oil use. I think all the brands that have an oil bath bar are pretty much the same way. You might see a slightly "oily" look on the end of the bar where the vent is. You should not see any seepage or oil stains on the top of the bar around the rotors.
Cool deal - I figure I will go straight SAE 90 since that is what the manual calls for. TSC doesn't carry straight 90. It seems everybody has a multi-weight. I am going to call my dealer to see what they have to offer.
D.
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 1.5 Ton Crane Utility Truck (A59230)
2005 Mitsubishi...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
