The old log splitter thing again
   / The old log splitter thing again #1
acohen100
Southern Vermont
Kubota BX24
So I just started splitting my own wood this year. I bought an older, used, fixed, horizontal splitter for about $600. Gets the job done but after splitting about 2-3 cords I now officially have sciatica from lifting all of the heavy logs onto the beam.
To save my back I looked at a vertical splitter but I am bothered that you can't really do 4-way with the vertical design and the wedge on the ram. It seems that the only compromise is a log lift but those are then pretty darn pricey.
I have looked at Timberwolf but they are all lower TON ratings, smaller engines and priced way over other models. Although they seem to be good quality they also seem like a bad bargain.
Seems like Honda engines are preferred but different models with the same engine offer all different ranges of power, and I have no idea why - for example, the TW with a 5.5 Honda gives you 20 tons of force and a Northstar with the same engine rates at 30 tons.
After looking at all of them the Northern Tool model seems the best combination of power, design and cost.
Comments?
   / The old log splitter thing again #2
My two cents......
I have an MTD Yard Machines splitter and love it. It has the 5.5 Honda and rated at 27 ton. This is the same as the Troy-Bilt and Cub Cadet at the big box stores. It splits everything i've thrown at it including knotty elm. Perhaps one of the things i like most is the height. Its at a very comfortable height to work at. I've almost never used it verticle, since for me, its just too darned uncomfortable hunching down on the ground to work. I split alot of big stuff, and whatever is too big to lift..... i roll the rounds up a couple 2x6s i lean on it like a ramp. Of course, i get spoiled whenever my FIL is around, since his is always happy to fire up his Bobcat and set the chunks on the splitter with a set of tongs.
I looked at the Timberwolfs, and they are very well made. They have grease fittings everywhere and are very serviceable. The cheapest Timberwolf was nearly a thousand dollars over what i paid for my splitter. I found that the Timberwolfs sat much too low for me to comfortably work at. Splitting any amound of wood close to knee height left me with a killer backache. I also found that, though the four way wedge is nice, it doesn't suit splitting large rounds very well. And, having a peice that is big enough to be split many times would leave you lifting the piece back ahead of the wedge to be split again..... over and over. No fun with rounds two to three feet across. With the wedge on the ram, the piece of wood stays right in front of you, where you want it. One great thing about the Timberwolfs (and similar), is they are good for production work, where you are splitting consistantly sized wood and dropping it off the end of the splitter onto a conveyor.
I've not operated a Huskee fron TSC, but i've read lots of good feedback on them on other forums. The sell up to 35 ton, but seeing what i've done on my 27..... i can't possibly imagine i'd need anything that big.
Whatever you think you'll buy....... i strongly recommend trying it before you buy. Make sure its comfortable for YOU to operate. As far as not having a four way wedge, i find is more technique than anything. I start a split, back the ram up a little..... flip the piece of wood end for end and rotate it 90degrees at the same time. Then drive the wedge in again and i've got a piece split in four pieces in less than a full stroke. Much quicker than it sounds.
One mod i did to my splitter..... made a "shelf" that bolts to the far side of the splitter. When doing pieces that take multiple splits, it gives the wood a place to rest so i'm not constantly picking the same piece of wood off the ground and lifting it back onto the splitter. Another real back saver.
   / The old log splitter thing again #3
I found a few pics from a few years ago. For your aching back, you need a FIL (or neighbor) like mine. Any excuse to get the Bobcat outta the shop! When i'm splitting alone, i'll roll a chunk like this up my 2x6 ramps onto the splitter no problem. Notice my "prototype" shelf made out of plywood. It worked so well a made it permanent.
   / The old log splitter thing again #4
Great Pictures... I think I will add a shelf to mine.
Thanks for the idea!
   / The old log splitter thing again #5
I like having the option of splitting "vertical", but I avoid doing so as much as possible.
My first splitter was a 3-point mounted type with vert/horiz. option. I didn't care for having the tractor so close to my work, as well as having the tractor sitting there at fast idle all day long. I went with a 27t Troy Bilt (w/Honda engine) I also don't care much for jumping on and off the tractor while using a loader to put big logs on the splitter. That's where the vertical position comes in handy. I can roll those logs into position ON THE GROUND.
"Tonnage" ratings vary, depending on (A) size/type of cylinder, (B) cycling speed, (C)pump/engine size. Some splitters use a smaller engine with a slower rate pump, yet still have the capacity of some higher powered, faster units. In the end, I can't keep up all day with a high speed splitter, so the smaller engines, with their lower fuel consumption, seem to fit me best.
The "shelf" is a must. Many splitters come with a small version. A larger one is very handy.
I went from a 33 ton 3-point mounted splitter to a 27 ton trailer type. I've never missed that other "6 tons".
Unless you're using a very stout splitter, or always splitting relatively easy-to-split wood, the "X" wedge isn't really a factor. I've used one (a rental) and found on BIG logs it's an inconvenience. Smaller logs, just cycle wedge enough to split, back off, turn log 90 degrees, and cycle again.
   / The old log splitter thing again #6
there's a guy up the road from me that has a splitter that he added a hydraulic arm to......he just swings it over, picks up the log and then swings it in to place........his was a pretty simple design.......
   / The old log splitter thing again #7
No pictures to share, but I did the same thing with my 3-point mounted model. I removed it before the splitter was sold. I have plans to install it on the new splitter as time permits.
   / The old log splitter thing again #8
My two cents......
I think youve put this very well, about the true value of the "bells and whistles" vs what can easily be accomplished without. I find that often a bell or whistle that is nice to have, ends up being in the way in some fashion during the many instances that you dont need it. When I built my horizontal splitter I placed the top rail at about 24" knowing that changing the height up or down acouple inches would be easy. Turns out 24" works pretty darn good, allowing the height of small pieces added to reach my fingertips to be steadied while splitting, and still being low enuf to use a ramp of reasonable steepness for big pieces. I would certainly like to have vertical capability, but in sizing the H/Vs up I am not satisfied with the work station height and position provided in the horizontal setup. Certain ergonomic trade offs are made in allowing both positions, and they impact mainly on convenient horizontal use. Vert option would be nice, but its not very hard to get around the need for it if youve got a tractor/loader.
larry
   / The old log splitter thing again #9
Comments?
Good Mornin Acohen,
Im not really sure I should even be commenting on splitters because I have only owned mine for the past year ! So with that said Im certainly no expert and did the whole thing all these years with two mauls, 8 lb and 6 lb, along with some wedges and a 10 lb sledge :(
I bought my splitter from an HD rental locally. I payed about $735 used, although the unit only had 100 rental hours on it which I equate to about 70 hours of actual use. A friend that works there gave me the tip on the unit going up for sale and I jumped on it !:)
I really like the unit because of its vertical option, at 57 I cant lift 25" oak rounds, heck I dont think I ever could ! ;) What I find that works for me is, quartering a bunch of these monsters, and then tilting the splitter up in the horizontal to finish the job ! Im pretty a one man operation here so I have to go with what works ! In the horiz pos the splitter height is about 34", which is not bad IMO !
As a side note I really like Ductapes' work platform, and I might look into fabricating something like that, but make it easily removable in case it got in the way !
Back to the splitter, it has an 8 hp Honda and looking into the manual I believe it generates 27 tons of force, which honestly will split anything, and if it doesnt split it, it will just cut through it, crotch, knots etc...
Im also aware that if you bought the same unit new your in the neighborhood of $2500... ouch
Anyways, thats some of my feelings on this Speedco unit.....
   / The old log splitter thing again #10
In this neck of the woods, there is no large hardwoods, so everyone has gone to the little electric units that are less than $ 400.00 new. I had my doubt until my father in law split 30 cord over 3 winters and never had to use ear plugs. A guy might use one of these small units and rent a large unit for big rounds.
By the way, 3 inches of snow this morning and it is staying. winter is here
2019 Komatsu WA380-8 Wheel Loader, S/N A75147, PIN# KMTWA130TKNA75147, Turbo Diesel Engine, Komatsu (A59076)
2019 Komatsu...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Komatsu FD40T-7 Forklift (A54865)
Komatsu FD40T-7...
2008 CMTL Trailer (A55973)
2008 CMTL Trailer...
2005 Interstate StreamLine 14ft T/A Enclosed Cargo Trailer (A55973)
2005 Interstate...
