CJ4 oil
   / CJ4 oil #11
My 2008 Kubota owner's manual also specifcially states that "CJ-4 oil cannot be used in this tractor". This is a new MX5100 and looks like the rest of the wording makes me believe that I cannont use CJ-4 for non-EGR or internal-EGR, only for external-EGR.
   / CJ4 oil #12
I noticed Foothill's link references engine models D902-E2 and D902-E3. DieselPower's link doesn't list a model number.
My Grasshopper mower happens to use the same D902 engine, and I picked up some oil at my CaseIH dealer for it. I'm using the same 10w30 in my CIH tractor and the GH (Kubota Engine) mower. The Case oil is rated as CH-4, so it fits both recommendations by chance. If someone is looking for CH-4 oil, check your CaseIH dealer.
   / CJ4 oil #13
For the life of me I can't imagine why they would say to not use CJ-4. Its designed for today's modern EGR engines which tend to be harder on the oil.
Please help me out in interpreting this - Your link says "All Applications....CF4".
The other alternatives say "May be used" - - They dont say recommended or "use only x x or better. To me that means CF4 is the best choice.:confused:
larry
   / CJ4 oil #15
Maybe one of the Kubota dealers on here can clear this up, after all they sell and service the Kubotas.
I hope one of them will respond and clear this up.
With my new M5040, and Model V3007-DI engine the Operators Manual states that because I use Off-Road "High-Sulfur" fuel I can only use CF oil and that because I use CF oil it must be changed at shorter intervals.....that "shorter intervals" is pretty vauge....
There is no mention in my Operators Manual about whether or not I can use CJ4 oil.
When the service tech at the dealership was giving me the walk thru of the tractor prior to delivery he said that I could use Rotella.... not sure if he is correct or not.
I sent an e-mail to Shell and asked which version of Rotella I should be using with "High-Sulfur" off-road diesel and this is what I got back.
"In 2007 off-highway red dyed diesel sulfur content was reduced from >500 ppm (parts per million) to 300-500 ppm. Because the sulfur content is now lower, you can use either the CI-4+ or CJ-4 Rotella T 15W-40. API CD,CE or CF are old obsolete specifications. The CJ-4 version shows a 50% reduction in wear."
It seems from Shell's point of view that I can use CJ-4...... but nothing from Kubota.
Sure would be nice to know from Kubota if I could use CJ4 oil, while using High-Sulfur Off-road fuel.
Stu
   / CJ4 oil #16
Guy's I can tell you this much CJ-4 is the new recomened oil for over the road Egr equiped road tractor's as in tractor trailer.As a Fleet diesel mech. all are new 2007 &2008road tractors are to use this oil.Engine warr. are voided if a different oil is used.It is more expensive I can't imaigine why off road eqipment would use it,much greater expense the Kubota.
   / CJ4 oil
Stu
Does Shell still make a CI4 oil, the only one I can find is CJ4, maybe due to the fact that I'm in Calif and I don't think theres anything other than ULSD out here which is maybe why I can't find CI4 oil.
But again I question is Kubota the only one using these standards, why not MF,NH,JD?
   / CJ4 oil
I emailed Shell, they think that the CJ4+ is still available but only in the barrel, a little to much for me.:D
   / CJ4 oil #20
CI-4 is still available in smaller containers from some lubricants manufacturers.
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
2022 JOHN DEERE 333G SKID STEER (A52705)
2022 JOHN DEERE...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A52377)
2019 Allmand...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55218)
2015 Ford F550...
