I hope one of them will respond and clear this up.
With my new
M5040, and Model V3007-DI engine the Operators Manual states that because I use Off-Road "High-Sulfur" fuel I can only use CF oil and that because I use CF oil it must be changed at shorter intervals.....that "shorter intervals" is pretty vauge....
There is no mention in my Operators Manual about whether or not I can use CJ4 oil.
When the service tech at the dealership was giving me the walk thru of the tractor prior to delivery he said that I could use Rotella.... not sure if he is correct or not.
I sent an e-mail to Shell and asked which version of Rotella I should be using with "High-Sulfur" off-road diesel and this is what I got back.
"In 2007 off-highway red dyed diesel sulfur content was reduced from >500 ppm (parts per million) to 300-500 ppm. Because the sulfur content is now lower, you can use either the CI-4+ or CJ-4 Rotella T 15W-40. API CD,CE or CF are old obsolete specifications. The CJ-4 version shows a 50% reduction in wear."
It seems from Shell's point of view that I can use CJ-4...... but nothing from Kubota.
Sure would be nice to know from Kubota if I could use CJ4 oil, while using High-Sulfur Off-road fuel.
Stu
