Questions:
Say you are using the plow to do a small food plot that is a rectangle or square surrounded by trees.
So not knowing anything about plowing, you drive from one end to the other. You have to stop or crash into the trees, leaving a tractor's length of un-plowed earth. Using the flip over plow, what do you do at the end of the furrow? Turn the tractor and back up next to end of the furrow you just did, but all the way to the tree line? Then plow in the opposite direction until you hit that tree line? Seems to me there would be a dead spot at the end of each furrow that way? Am I wrong there?
Using a conventional plow and assuming there is enough room to turn the tractor (which you need anyway), plowing in a "circle" would only leave corners of the rectangle un-plowed, right? Or you could back up to the corner and plow at a 90 degree angle to get all four corners and after that continue with the circular plowing?
Which would leave less un-plowed earth on a small plot?
I'm asking...
