55 Gal drum gravity fed system
   / 55 Gal drum gravity fed system #1
Brahmus
South Louisiana
Can anyone running a similar system post pictures and pointers? I've got a brand new metal 55 gallon drum and would like to perch it about 5' or so, on it's side with a hose and valve.
Something low budget but something that will let me go a while longer before running back to the station and will not have me toting fuel cans around.
   / 55 Gal drum gravity fed system #2
http://www.tractorbynet.com/forums/oil-fuel-lubricants/122497-heres-mine-wheres-yours.html
How do you plan on getting it up there and how do you intend on getting it refilled?
Do your self a favor and put and elect 12 volt pump on it.:)
I did last summer but was dumb enough to do with out one for 3 years first.:eek:
http://i283.photobucket.com/albums/kk286/lb59/100_2303.jpg
Local marine station passes by the house twice a week. No issues on getting it filled. Living in my small town helps, my wife and his daughter are very good friends. I plan to lift it with two straps and the FEL. I plan to keep it outside the shop and I don't really wanna route a pump.
Why would gravity fed not work?
   / 55 Gal drum gravity fed system #4
*Why would gravity fed not work?
*It will but a pump is SOooooooooo much nicer !
   / 55 Gal drum gravity fed system #5
Thanks to my Pump There is no lifting so The tractor and FEL isn't needed.
With the pump i can empty and fill the drum both.
   / 55 Gal drum gravity fed system #6
We had a well built steel rack to hold 4 55 gallon drums... 3 grades of lube oil and one for diesel. It was a great gravity system and all the drums had quality bronze valves with spring safeties.
All was well until we got a call from the new Fire Marshall. He wrote us up and gave us 10 days to get rid of the gravity system. Pumps were ok... just not gravity. Something about gravity feeding a fire.
I'm not sure I understand how gravity fed would make a fire situation worst...
   / 55 Gal drum gravity fed system #9
because the drain ie fill hose is at the lowest point it will empty the whole drum of fuel into a fire.
Also since the drum is elivated that puts it above the fire so it can feed the fuel into the fire real easy .
   / 55 Gal drum gravity fed system #10
I had a 550 gallon gravity fed system for years before I had any issue. I'd seen many other farmers with similar setups and they didn't have a containment system for a spill either. Mine worked so well that I quit running up the steps to turn the valve on and off each time I used it. The valve in the filler handle worked fine and never leaked. This was fine until the hose rotted through and failed right after the valve and filter outside the tank. What a mess! I don't have a clue how much money and how many hours that mistake cost me.
I now have that same tank sitting inside a containment tank on the ground with a regular 120v electric pump. Although the gravity fed unit worked fine, I have to admit that I like the 120v electric transfer pump with the auto-shutoff nozzle and all. I don't have to worry about remembering to turn the valve on and off and it's inside a containment tank anyway should a leak occur.
Other than the real possibility for a spill and having no containment system (at least I don't think you mentioned one), a gravity feed system will work fine for low volume. Many suppliers will not fill your tank, even a really small 55 gallon tank) if you don't have the basic EPA requirements covered. I think they can be nailed by the EPA should you have a leak and not have a proper containment system. At least that is what my suppliers have told me. Being legal with a containment tank pretty well eliminates a gravity fed system anyway unless you dig a pit around your tank and line it with plastic. My 550 gallon tank is still considered relatively small by most comparisons and the containment tank it sits in cost me around a hundred bucks or so. At least I'm legal now. Besides, the spill I had a few years ago was not only costly, but it took a ton of my time to fix. Good luck!
Sky Trak 10054 Legacy 10K Telehandler (A54865)
Sky Trak 10054...
2008 Ford F-350 Service Truck (A53422)
2008 Ford F-350...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
