Coating the underside of a new grooming mower
   / Coating the underside of a new grooming mower #11
What did you use for Graphite paint? I have not seen any at our local stores and I have two older mower decks that are rusting and catch lots of grass. I would like to clean them up and paint them. Hoping that if the deck is smooth the grass will be less apt to stick. TIA
   / Coating the underside of a new grooming mower #12
Jim,
I get this stuff at my local Farm Store. Comes in spray cans, Quarts and Gallons. I use the brush on stuff for the decks and mold boards. I also like it for parts that need lubed, but I don't want grease and oil all over myself. Dries very fast.
NOTE: I use the same brush all the time. They get hard and dry, but I just tap the bristles gently with a hammer against something hard and the dry graphite flakes away.
   / Coating the underside of a new grooming mower #13
Jim,
Thanks, we have no Farm Stores around here... I will double check to see if our local TSC carries it, or can get it. I don't remember seeing it last time I was there.
   / Coating the underside of a new grooming mower #14
It's called slip-plate and I've been using it for years with great results. It keeps the acids from mowing from eating into your deck.
Step 1 - Apply it with a brush to get a thicker coat than spray for longer lasting results. Let dry.
Step 2 - Often not done but must be done for best results. Burnish the coating - I use one of those foam sanding blocks from HF - by sanding or wire brushing all over, especially the tight areas and curves. It will leave a very smooth shiny slick finish that's good for at least 1 season.
   / Coating the underside of a new grooming mower #15
You can also find Slip Plate at Grainger...
Edited to add - They had to order my gallon, but it came in within a couple days..
Brian
   / Coating the underside of a new grooming mower #16
That's a great idea. I know it really shines up with wear. The smoother and slicker the deck is, the less the grass sticks. THANKS!
   / Coating the underside of a new grooming mower #17
I was all worried about my new expensive bush hog but it has a nice dark green coating of plant material and I don't think about it anymore.
   / Coating the underside of a new grooming mower #18
whare can i find graphite paint???? sonds like a good idea, i just baut a new mower deck for my simplicity 7116 i think ill coat the underside even now its got brand new paint.
   / Coating the underside of a new grooming mower #19
Around here, Tractor Supply carries one brand.. You can also order Slip Plate from Grainger from a local store or online..
Brian
   / Coating the underside of a new grooming mower #20
Clean up would be easy, but rust might be a problem.
I agree with the hose flush fittings. They really do work.
My mower is 2 years old, and no paint is left under the deck. However, it's shiny and smooth with only a few specks of light rust. You flush the deck with the blades spinning, and the deck dries out very quickly so it doesn't rust. I suppose you could spritz a little WD40 into each fitting, but I don't think it would prolong the life of the deck due to rust. It may be a good thing to do before winter storage.
A friend of mine has the ultimate solution. When he finishes mowing, he runs over a pile of pine cones. They blast every last bit of grass off of the deck, leaving it shiny and dry. :D
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2011 TROXELL COMPANY 130BBL VACUUM TRAILER (A53843)
2011 TROXELL...
2017 Chevrolet Tahoe (A52377)
2017 Chevrolet...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
