best modification?
   / best modification? #1
twodogs
Pittsburgh, PA
Kubota B7800
What is the best (most useful) modification that you have made to your tractor?
   / best modification? #2
FEL bucket hooks
   / best modification? #5
chain hooks on FEL
made a carry-all that fits on 3ph hay fork
gooseneck ball on 3ph hay fork to move trailers
chain holders in FEL hollow horizontal support arms
rear lighting
hydraulic top link
I couldn't tell you which of these is the best... they all are!
   / best modification? #6
I didn't like the fact that it took about 20 minutes to fold the foldable roll bar(ROPS) down and/or up,because the bolts you need to unscrew are in an awkward place and a very fine thread. So I bought new grade 8 bolts the same size as the originals and ground the threads off so the bolt would fit thru the welded nut, then drilled a 3/16 hole thru the bolt, for a hairpin retainer to hold it in place, with a washer for good measure.
Now it takes maybe 1/2 minute to put the ROPS up or down and the part I ground is not in the part of the bolt that would take stress if (God forbid) the roll bar was needed. I've already found out that a 6 1/2 foot roll bar doesn't fit under a 6 1/4 foot doorway, so I need a way to get the bar up and down quickly, else I'm tempted to leave it down.
simonmeridew
   / best modification? #8
Bucket hooks are best.
2nd best was installing a Racor R12 fuel filter before the undersized OEM filter.
(both can be seen in photo)
   / best modification? #9
Welded on chain hook on the FEL.
   / best modification? #10
I would have to say:
1: Boat/RV etc drink holder from Cabellas. No- Shakee Drinkee.. Just Swingee
2: The carry all... Cheap thing to buy or build. (I bought a KK unit) So many uses......
3: The wifey.. I can stand back and watch her play.. Need to get her a set of ear buds and headphones for her Ipod. Will never hear from her again.
Tom
LEEBOY 400T DOUBLE DRUM ROLLER (A52707)
LEEBOY 400T DOUBLE...
2023 Kubota RTV-XG850 Sidekick (A55315)
2023 Kubota...
40006 (A55788)
40006 (A55788)
2020 Deere 50G (A53317)
2020 Deere 50G...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
