best modification?
   / best modification? #1
twodogs
Pittsburgh, PA
Kubota B7800
What is the best (most useful) modification that you have made to your tractor?
   / best modification? #2
FEL bucket hooks
   / best modification? #5
chain hooks on FEL
made a carry-all that fits on 3ph hay fork
gooseneck ball on 3ph hay fork to move trailers
chain holders in FEL hollow horizontal support arms
rear lighting
hydraulic top link
I couldn't tell you which of these is the best... they all are!
   / best modification? #6
I didn't like the fact that it took about 20 minutes to fold the foldable roll bar(ROPS) down and/or up,because the bolts you need to unscrew are in an awkward place and a very fine thread. So I bought new grade 8 bolts the same size as the originals and ground the threads off so the bolt would fit thru the welded nut, then drilled a 3/16 hole thru the bolt, for a hairpin retainer to hold it in place, with a washer for good measure.
Now it takes maybe 1/2 minute to put the ROPS up or down and the part I ground is not in the part of the bolt that would take stress if (God forbid) the roll bar was needed. I've already found out that a 6 1/2 foot roll bar doesn't fit under a 6 1/4 foot doorway, so I need a way to get the bar up and down quickly, else I'm tempted to leave it down.
simonmeridew
   / best modification? #8
Bucket hooks are best.
2nd best was installing a Racor R12 fuel filter before the undersized OEM filter.
(both can be seen in photo)
   / best modification? #9
Welded on chain hook on the FEL.
   / best modification? #10
I would have to say:
1: Boat/RV etc drink holder from Cabellas. No- Shakee Drinkee.. Just Swingee
2: The carry all... Cheap thing to buy or build. (I bought a KK unit) So many uses......
3: The wifey.. I can stand back and watch her play.. Need to get her a set of ear buds and headphones for her Ipod. Will never hear from her again.
Tom
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A57880)
2015 FREIGHTLINER...
Cushman Electric Utility Cart (A55851)
Cushman Electric...
2011 Chevrolet Malibu 2LT Sedan (A55853)
2011 Chevrolet...
UNUSED FUTURE PAIR OF 7" MINI RUBBER TRACKS (A57193)
UNUSED FUTURE PAIR...
2008 Dodge Ram 1500 (A55973)
2008 Dodge Ram...
UNUSED RAYTREE RMBD50 50" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
