best modification?
   / best modification? #11
Loaded my rear tires. Haven't done that yet to my L4400, but I will... some day.
Sharpened my FEL bucket edge real sharp. It shaves up to 1-1/2" brush flush with the ground like a giant razor. When I bush hog around my fence line, I set my bucket about a foot high and level, and any limbs sticking out gets nipped and fed to the bush hog.
Got to figure out how to put a level indicator rod on my FEL. The stock "level indicator" is going to get my bucket all bent up. :(
I know this is off topic, but I put removable casters under my bush hog. Makes it super easy to roll it and line it up with the 3 point hitch. Gotta figure out how to do that with my new Bush Hog.
   / best modification? #12
I like that idea! So simple...why didn't I think of that earlier?
   / best modification? #14
I put several upward facing prongs on the top of the loader bucket so logs can't roll back and sit on my lap!:D
   / best modification? #15
Great idea. Wonder is a solid sheet across the rear of the loader would prevent my LA703a loader from dumping dirt in my lap? :rolleyes:
   / best modification? #17
Adding rear remotes and CCM hyd. top link. Takes using all my implements to a new level.
   / best modification? #18
These d-rings from Northern. High capacity. Cheap. Easy to mount using grade 8 bolts.
Also, two heavy duty zip ties on the ROPS to hold my Fiskars axe in. Don't leave home without it!
   / best modification? #19
Just for interest; yesterday I saw a tractor with a very broken hood due to something falling off the bucket and onto the hood!:D
   / best modification? #20
What is the best (most useful) modification that you have made to your tractor?
Back in 2002, I converted my L5450's pto gearbox so it has 2 speeds - 540 and 750 rpm. The job details and more pics are posted here. I recently got a second L5450 and converted that one the same way. It is handy to have the higher speed for low-power attachments - lets the engine loaf at around 1700 with the pto at full 540rpm.
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
1472 (A51247)
1472 (A51247)
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A53421)
2025 Single...
294 (A52706)
294 (A52706)
