best modification?
   / best modification? #11
Loaded my rear tires. Haven't done that yet to my L4400, but I will... some day.
Sharpened my FEL bucket edge real sharp. It shaves up to 1-1/2" brush flush with the ground like a giant razor. When I bush hog around my fence line, I set my bucket about a foot high and level, and any limbs sticking out gets nipped and fed to the bush hog.
Got to figure out how to put a level indicator rod on my FEL. The stock "level indicator" is going to get my bucket all bent up. :(
I know this is off topic, but I put removable casters under my bush hog. Makes it super easy to roll it and line it up with the 3 point hitch. Gotta figure out how to do that with my new Bush Hog.
   / best modification? #12
I like that idea! So simple...why didn't I think of that earlier?
   / best modification? #14
I put several upward facing prongs on the top of the loader bucket so logs can't roll back and sit on my lap!:D
   / best modification? #15
Great idea. Wonder is a solid sheet across the rear of the loader would prevent my LA703a loader from dumping dirt in my lap? :rolleyes:
   / best modification? #17
Adding rear remotes and CCM hyd. top link. Takes using all my implements to a new level.
   / best modification? #18
These d-rings from Northern. High capacity. Cheap. Easy to mount using grade 8 bolts.
Also, two heavy duty zip ties on the ROPS to hold my Fiskars axe in. Don't leave home without it!
   / best modification? #19
Just for interest; yesterday I saw a tractor with a very broken hood due to something falling off the bucket and onto the hood!:D
   / best modification? #20
What is the best (most useful) modification that you have made to your tractor?
Back in 2002, I converted my L5450's pto gearbox so it has 2 speeds - 540 and 750 rpm. The job details and more pics are posted here. I recently got a second L5450 and converted that one the same way. It is handy to have the higher speed for low-power attachments - lets the engine loaf at around 1700 with the pto at full 540rpm.
Takeuchi TB016 (A53317)
Takeuchi TB016...
1999 Vermeer SC505 Walk-Behind Tracked Stump Grinder (A55851)
1999 Vermeer SC505...
UNUSED FUTURE ELECTRIC BICYCLE (A57193)
UNUSED FUTURE...
Caterpillar 906M (A53317)
Caterpillar 906M...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A57192)
KNOW BEFORE YOU...
UNUSED FUTURE KH72 72" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE KH72...
