Replacement parts for a JD 127 gyramor cutter
   / Replacement parts for a JD 127 gyramor cutter #1
fishfighter
Member
Guys,I need some help finding some bolts that hold the blades for this cutter.I tryed the local dealer which was a joke.I was able to find the blades,but no bolts.I did email JD,with no reply,so if anybody know of a parts supplier,let me know.
Thanks!
   / Replacement parts for a JD 127 gyramor cutter #2
JDParts.com lists bolts and nuts for the JD 127. Select By Model Search, then enter 127 where it says Enter Model Number, then pick Cutter, Rotary. The resulting listing has parts for 3/8" blades and 1/2" blades. Get the part numbers you need and have JD order them for you, or click on each part to get dimensions and try to find them from your favorite farm supply or an online parts place.
Good luck.
   / Replacement parts for a JD 127 gyramor cutter #3
There should be a series # (NOT serial #) on the mower. Series #3 will use 3/8" blades. Series #4 will use 1/2".
Good luck.
Thanks for the info.I just can't see paying over $40 for each Bolt,nut,washer and pin.Thats' unreal for sure.There has to be a aftermarket replacement part for this being there were a half a million made.Glad I am finished cutting for the winter.That will give me time to find a replacement.Thanks again guys.
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2014 CM TRAILER CARGO (A55745)
2014 CM TRAILER...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
PARTS ROOM W/SHELVES (A55745)
PARTS ROOM...
