Replacement parts for a JD 127 gyramor cutter
   / Replacement parts for a JD 127 gyramor cutter #1
fishfighter
Guys,I need some help finding some bolts that hold the blades for this cutter.I tryed the local dealer which was a joke.I was able to find the blades,but no bolts.I did email JD,with no reply,so if anybody know of a parts supplier,let me know.
Thanks!
   / Replacement parts for a JD 127 gyramor cutter #2
JDParts.com lists bolts and nuts for the JD 127. Select By Model Search, then enter 127 where it says Enter Model Number, then pick Cutter, Rotary. The resulting listing has parts for 3/8" blades and 1/2" blades. Get the part numbers you need and have JD order them for you, or click on each part to get dimensions and try to find them from your favorite farm supply or an online parts place.
Good luck.
   / Replacement parts for a JD 127 gyramor cutter #3
There should be a series # (NOT serial #) on the mower. Series #3 will use 3/8" blades. Series #4 will use 1/2".
Good luck.
Thanks for the info.I just can't see paying over $40 for each Bolt,nut,washer and pin.Thats' unreal for sure.There has to be a aftermarket replacement part for this being there were a half a million made.Glad I am finished cutting for the winter.That will give me time to find a replacement.Thanks again guys.
2007 CATERPILLAR 420E IT (A55745)
2007 CATERPILLAR...
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A55852)
2002 Western Star...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
PNEUMATIC GREASE PUMP W/TANK & CART (A55745)
PNEUMATIC GREASE...
