Mineral or Paraffin base
   / Mineral or Paraffin base #1
N1ST
Enfield, CT
Kubota B7800
Walmart sells a mineral base and paraffin base grease in a tube. Is one better than the other for general tractor use?
   / Mineral or Paraffin base #2
For general applications the paraffinic base would be better. There are several different types of paraffinic base oils but in general they will offer better oxidation resistance, demulsability (water resistance) and a higher volitility rating.
   / Mineral or Paraffin base #3
Just make sure it has the EP designaiton if you are using it to lubricate your FEL or BH. EP grease is used for Extreme Pressure applications.
Thanks guys. I'll use this in sposts that have zirks.
I've tried using greese on the "eyeballs" that the pins go through on the 3 point hitch arms, but it turns black and drys out. Dupont sells a Teflon multi-use dry wax lubricant that doesn't attract dirt. Do you think this will lubricate these better than rubbing on greese?
   / Mineral or Paraffin base #5
I use fluid film which I believe is a parafin base on my 3pt "eye balls". It seems to work well. I got mine mail order but I believe John Deere dealers all carry it.
Fluid Film: Corrosion Preventive, Lubricant and Rust Inhibitor
   / Mineral or Paraffin base #6
Thanks for the name; I saw a can of this a few years ago and have been trying to remember the name so I could acquire a can. My loco, er local John Deere dealer does not stock it, about all he stocks is a bad attitude, but 2 local commercial lawn equipment dealers do carry it. It is listed a lanolin based.
   / Mineral or Paraffin base #7
We tried the fluid film and it was poor when used on outdoor elements...
TANK MANIFOLD (A58214)
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
207281 (A52708)
207281 (A52708)
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
Sterling AT (A56438)
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
