$15,900 sound good for a CK30
   / $15,900 sound good for a CK30 #11
Intel
Quick attach 66" bucket standard
Push button 4wd
push button pto
you can raise and lower the 3 point from the rear.
1 set of aux remotes standard.
deluxe suspension seat
and of coarse size
Much more room for the big guys!
I assume these are all features of the DKSE, vs. The CK.
One of the reasons I would go for the DK35SE over the CK35 is that the
former has a much less vulnerable underside. The CKs have very exposed
hyd components, esp the big filter.
What is the price diff betw a DK35SE and a CK35, both set up the same
with HST, one rear rmt, FEL, etc?
   / $15,900 sound good for a CK30 #12
$1,050.00 on my lot.
   / $15,900 sound good for a CK30 #13
I can tell you the price you got on the 3400 is way high, like $3-4,000 too high.
   / $15,900 sound good for a CK30 #14
Nothing negative about the DK35se but do yourself a favor and get a price on the DK40se as well. As I recall it was not a lot more in identical configuration and the loader strength is remarkably better with the KL401 over the KL351. The 40se also has bigger tires/axle and is higher off the ground. Engine power is not that different (38 vs 41) but it is still IMHO a lot more tractor.
   / $15,900 sound good for a CK30 #15
Wallace, do you think a 6'3" guy will be cramped in the CK 30. I was on one the other day and I was disappointed with how close the seat was to the steering wheel. I am thinking seriously and like the OP have moved to Kioti from the L3400.
   / $15,900 sound good for a CK30 #16
I am 6' 1", and I have no issues on my CK30, did you check to see if the seat was all the way back. It is adjustable, as well as the steering wheel.
   / $15,900 sound good for a CK30 #17
I'm 6'5", 230 and I was comfortable on a CK20. Even more comfortable on a DK40se though.;)
   / $15,900 sound good for a CK30 #18
I'm 5'5" and I fit comfortably on a tricycle. Still find those full sized 10 speed huffies to be a little tricky though. :) :) :)
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Charlotte County (A50323)
Charlotte County...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
UNUSED 3 PRONG BALE SPEAR (A51248)
UNUSED 3 PRONG...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
40' CONTAINER (A51248)
