Bottom plow for a 24 HP tractor
   / Bottom plow for a 24 HP tractor #1
jester7891
NJ-PA border on the Deleware
Kubota B7610
I have a 24 HP B 7610 Kubota and I would like to do some planting in the spring. The land used to be scrub forest and brier bushes until I let loose my brush hog. This land has never been worked before. Is my machine powerful enough for a 3 pt double bottom plow (possibly triple)? Anyone have any ideas on the best brand/type? Thanks, Jester
   / Bottom plow for a 24 HP tractor #2
You have a great sense of humor! A 7610 pulling a 3 bottom plow thru virgin soil!
Uh, no. Not a gonna happen.
If you have sharp blades, set up properly, good tires, and the soil is helpful, you might be able to pull a 2x12. It's gonna be close. You would be certain pulling a single bottom plow, but that takes some time to do.
jb
   / Bottom plow for a 24 HP tractor #3
For breaking chances are a single bottom would be optimum. If you are working cultivated soil two bottoms should work. :D
Me thinks but There could be some error in my thinks machine!:eek:
A picture of a three bottom plow attached just for comparison sake.:)
   / Bottom plow for a 24 HP tractor #4
A middlebuster single would be what you start with in virgin soil.
   / Bottom plow for a 24 HP tractor #5
Jester, I was out plowing last week with my Yanmar 186D. It has an 18 hp engine and it 4WD. I have a Leinbach 19-12 single bottom plow. I was working in an established field (sandy loam) smoothing out deep machinery ruts. The single bottom 12 is all my tractor can pull and I have to lift it up when it gets too big of a bite. Unless you are doing it for money plowing is really fun so a smaller plow just means more seat time. A smaller plow would also allow you to plow deeper and run faster. One problem I had was balls pf bean stalks building up on the plow because they couldn't harvest where the ruts were. I guess that would be helped by the optional coulter. The Leinbach is solid and I got it used for $150.
Chris
   / Bottom plow for a 24 HP tractor #6
Double bottom (possibly triple)- I don't think so. This summer I picked up a 3 pt single bottom (16" share) that was from a Ford 8N. I'm hoping that my JD2305 will pull it through my garden without too much difficulty! Good luck! Frank
   / Bottom plow for a 24 HP tractor #7
Wayne is right on, you would be having fits with any type of plow in those conditions. With anything other than a middlebuster or possibly a single you will spend more time off the tractor getting the plow unplugged than you will plowing.
   / Bottom plow for a 24 HP tractor #8
A good friend has the same tractor as you. To the point, forget the idea of THREE bottoms real quick like, don't count on TWO, and hunt for a decent single bottom plow. My friend has a Leinbach single (14"?) and it's ALL his tractor wants in most cases. You MAY have the HP for more, but the weight and available traction is such that a single bottom plow is plenty.
   / Bottom plow for a 24 HP tractor #9
Not sure how much planting you intend to do but a tiller the width of your tractor might be your best bet.
   / Bottom plow for a 24 HP tractor #10
I read something a while back that was rating plowing efficiency, they took a 4 bottom plow tractor and put 2 16's on it so it could go faster. They also took a 3 bottom tractor with a 3 bottom plow, slower ground speed. The larger tractor actually plowed more acres in the same period of time. So if you have a single bottom plow in tough soil, then in medium soil you can speed up and plow more land per hour up to the HP limit. Actually a plow works better at a faster rate of speed anyway.
The old US built 24 HP tractors could pull 2 14's or 16's in loam soil, but they were heavier, larger displacement engines, larger tires. But they could pull that plow at speeds of near 4 mph.
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
2015 Caterpillar 314E L CR (A53314)
2015 Caterpillar...
2007 Yard Dump Truck (A55973)
2007 Yard Dump...
