Where to connect hydraulic lines
   / Where to connect hydraulic lines #11
Well I bought the adapter plate and hooked everything up and it works like a charm. Now the only thing missing is snow. Thanks for the replies. One more question; if i decide to unhook the valve when i dismount the plow, do i plug the in/out ports on the sandwich adapter plate or do i need to keep the flow there?
I believe when the input and output hoses from the plate are not being used, you have to connect them together, other wise the 3pt wont work. I'm not sure if it would cause any damage to the pump though. I have one of those plates to run my FEL and it works great. I haven't taken the FEL since i bought it, but have it burned in my mind that if I do I have to plug those two ports together.. They are pretty adamant about that in the instructions.
Wedge
   / Where to connect hydraulic lines #12
The sandwhich plate must have flow thru.. so ports in and out tied.
soundguy
   / Where to connect hydraulic lines #13
Wedge
Yep.. or the pump runs in constant relief and no hyds to the 3pt...
soundguy
OK that makes sense. I'll probably just take the whole thing (plate and all) off at the end of winter. Thanks for all the help.
I got to actually plow snow yesterday with it (about 6") and it worked really good. I'm just waiting now for some real snow to see how it does:)
   / Where to connect hydraulic lines #15
If you use QC's on the plate you could make up a short hose to use when plow is off tractor.
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A55302)
2018 John Deere...
COOLTECH 34288 (A55745)
COOLTECH 34288...
2001 Ford F150 (A50121)
2001 Ford F150...
Informational Lot - Shipping (A55302)
Informational Lot...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
