BX 1500 Aux. Hydraulics?
   / BX 1500 Aux. Hydraulics? #1
Prodirt6000
Hi everyone,
Does any one know if on the BX 1500's hydraulic pump there is any outlet ports for hoses that can be routed to the back for a small cylinder for a claw? Or if there is anything at all that can be done. I know I could do it if I took off the front loader, and ran a hydraulic hose or two to the back, but I will need the loader on most all the time.
Thanks alot
   / BX 1500 Aux. Hydraulics? #2
As far as I know, Aux hydraulics can be added to any BX. I asked the same questions today about a BX1860 and my dealer said $600 installed.....I did not get into specifics about part numbers and part prices though.
   / BX 1500 Aux. Hydraulics? #3
I know on the later model BX's you can order rear remotes that mount on the inside of the ROPS (I think) and plum into the hydraulic block on the transmission - no need to tap into the pump and run long hoses. Check with some of the dealers who frequent here.
There is also this thread http://www.tractorbynet.com/forums/kubota-owning-operating/125660-bx7326-rear-aux-kit-install.html laying out the install process on a BX2350 pretty clearly. If I ever get the rear remotes, I plan to do the install myself.
So does anyone know where I could find the kit to do it? I read that link you said and the one guy there said it was a pretty simple install. Sure would be nice to have if I could find it for the right price.
   / BX 1500 Aux. Hydraulics? #5
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2003 Ford F-550 4x4 Terex TL38P 38FT Bucket Truck (A51692)
2003 Ford F-550...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2018 FREIGHTLINER...
2024 78in Screening Bucket Skid Steer Attachment (A51691)
2024 78in...
2024 Kubota BX23S (Dothan, AL) (A50123)
2024 Kubota BX23S...
