chevyzr2s10
Member
Im am planning to build a FEL for my Cub Cadet 1204. It has a Kohler Magnum 12HP engine. I plan to run the pump via belt drive off of the front electric clutch PTO.
I am considering running the following pump.Burden Sales Surplus Center Item Detail My engine turns about 3600rpm at full speed. I plan to gear down the pump to turn about 2500rpm at max speed. Which should give me a little over 7 GPM at full speed.
I am considering the following cylinders for both the bucket and arms. Burden Sales Surplus Center Item Detail They seem like a good deal and the stroke and length should work out good.
My questions
1. Is the DYNAMIC pump a good one? It is a good price but I am concerned about longevity because it is aluminum. If not, can you reccommend a different brand.
2. Does the pump (.73 displacement) seem like a good match for my application? If not, can you reccommend a size.
3. Do the cylinders seem good for my application?
4. Can you reccomend a valve for my loader? I would like a joystick type. Do I need the regeneration feature for my size loader? I have found a loader valve on Ebay which dosen't have regen for a good price, but im not sure about the quality. What is the best place to get a good valve for a good price?
5. Any other advice you can offer for me.
Thank you I really appreciate your help. I am new to TBN but it has been extremely helpful .
My questions
