Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Considering it is a valve you are moving to provide hyd pressure.. you will need to observe where the engagement occurs, after a small lag, and then maybee mark it so you will always know where it is.
here's a pic of a 5000 pto valve setup.
soundguy
soundguy
Yeah, I realised that. And I always engage it a at low idle.
The difficulty is that (unlike a transmission clutch) there seems to be no 'feel' what so ever. I can't tell I have reached a point of bite until BANG; it comes in like a switch being turned on. Really difficult to feather.
This isn't helped by the fact the clutch doesn't appear to be sprung. On a normal transmission clutch a spring holds the plates together. The hydraulics are only used one way - to part it. By contrast, on the PTO clutch there is no resistance to lever movement at all. I assume the hydraulics are two way. Is this right?
Duncan
