removing 4320 Deer from pond
   / removing 4320 Deer from pond #11
It took a Chevy to get the job done.... I second the vote to turn the Dodge around. The side view pull angle would put a large downforce on the drive axle (Although these Rembrandts might have succeeded in putting the Dodge in the drink, too)....
   / removing 4320 Deer from pond #13
That was dangerous as heck the way everyone was standing around a tight chain. Also, pulling a heavy load in reverse is the worst way to do it. A ring and pinion is made to take the load in the forward direction. Pulling in reverse is a good way to break your gears.
I am curious about the statement...have you read that somewhere so I can look it up? (ring-pinion part)
   / removing 4320 Deer from pond #14
This is a good video on youtube. Somehow the guy managed to back his Kubota into a pond. I think maybe he was trying to cut the grass at the edge of the pond with the bushhog. Yes, there is a bush hog attached to the back of that tractor! That's probably what kept it from going in completely. I guarantee you he had to clean his britches out after he got back home!!
YouTube - I've Fallen and I Can't Get Up!
   / removing 4320 Deer from pond #15
Yea, that's probably been my favorite picture for some time. Just the beginning makes you laugh. I'd like to hear his "manly" scream when he started sliding!
Kyle
   / removing 4320 Deer from pond #16
Do you think he'll buy a sickle bar mower before he tries to mow around his pond again?
   / removing 4320 Deer from pond #17
If you just look at the profile of ring and pinion gears you can see that one side is stronger than the other.
If you google it you can find quite a bit of info on it.
Also, there are some threads about it on Ford Truck Enthusiasts .com.
I don't know how much difference it makes but if I am pulling someone out and my truck is on dry pavement I will always do it from the receiver hitch. If you are on dirt, I think the tires will slip before you do any real damage.
   / removing 4320 Deer from pond #18
Yep, all you have to do as look at a ring and pinion set and you can intuitively see that it is made to go in one direction most of the time.
Having said that, I've done a lot of pulling in reverse simply out of necessity. I think it would take an extreme situation or abuse to cause a failure....but pulling a tractor out of a pond might be just that sort of abuse.
   / removing 4320 Deer from pond #19
Wonder what frightened that Deere into the water ?
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
1993 Ford F700 Stakebody Truck (A51692)
1993 Ford F700...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2013 Hyundai Azera Sedan (A50324)
2013 Hyundai Azera...
2121 (A51244)
2121 (A51244)
