removing 4320 Deer from pond
   / removing 4320 Deer from pond #11
It took a Chevy to get the job done.... I second the vote to turn the Dodge around. The side view pull angle would put a large downforce on the drive axle (Although these Rembrandts might have succeeded in putting the Dodge in the drink, too)....
   / removing 4320 Deer from pond #13
That was dangerous as heck the way everyone was standing around a tight chain. Also, pulling a heavy load in reverse is the worst way to do it. A ring and pinion is made to take the load in the forward direction. Pulling in reverse is a good way to break your gears.
I am curious about the statement...have you read that somewhere so I can look it up? (ring-pinion part)
   / removing 4320 Deer from pond #14
This is a good video on youtube. Somehow the guy managed to back his Kubota into a pond. I think maybe he was trying to cut the grass at the edge of the pond with the bushhog. Yes, there is a bush hog attached to the back of that tractor! That's probably what kept it from going in completely. I guarantee you he had to clean his britches out after he got back home!!
YouTube - I've Fallen and I Can't Get Up!
   / removing 4320 Deer from pond #15
Yea, that's probably been my favorite picture for some time. Just the beginning makes you laugh. I'd like to hear his "manly" scream when he started sliding!
Kyle
   / removing 4320 Deer from pond #16
Do you think he'll buy a sickle bar mower before he tries to mow around his pond again?
   / removing 4320 Deer from pond #17
If you just look at the profile of ring and pinion gears you can see that one side is stronger than the other.
If you google it you can find quite a bit of info on it.
Also, there are some threads about it on Ford Truck Enthusiasts .com.
I don't know how much difference it makes but if I am pulling someone out and my truck is on dry pavement I will always do it from the receiver hitch. If you are on dirt, I think the tires will slip before you do any real damage.
   / removing 4320 Deer from pond #18
Yep, all you have to do as look at a ring and pinion set and you can intuitively see that it is made to go in one direction most of the time.
Having said that, I've done a lot of pulling in reverse simply out of necessity. I think it would take an extreme situation or abuse to cause a failure....but pulling a tractor out of a pond might be just that sort of abuse.
   / removing 4320 Deer from pond #19
Wonder what frightened that Deere into the water ?
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
