COLD STARTING
   / COLD STARTING #11
On your average night, you'll be freezing without a cab. I've been lucky, despite some record cold this January, some days never got beyond single digits & the nights were brutal, I never had to move snow during the extreme cold.
   / COLD STARTING #12
Dont want to be rude, but wind chill does not effect the starting of the tractor. The temp does but not wind chill.
/forums/images/graemlins/blush.gif
   / COLD STARTING #13
No but, it definitely affects whether you feel like going out & using the tractor.
   / COLD STARTING #14
SJM I have to hit the glow plug a half dozen times to get my 4110 started when it's +30. Maybe I need to be calling my dealer. Being new at diesel and tractors I thought this was just the way it was.
   / COLD STARTING #16
I would guess that you have some glow plugs no working, as I have started 4110's on my lot in below zero weather.
   / COLD STARTING #17
This is an old thread but, I've noticed Kioti CK owners discussing cold start issues. The 10 series Mahindra also has Daedong (Kioti) engines and I've never had an issue starting in the cold, even below zero. It does run like a typical cold diesel but, let it warm up, no problem.
I do wonder if other Mahindra dealers have had any complaints with the 10 series in the cold.
   / COLD STARTING #18
Thanks LAWALLSTRACTOR, I'll give my dealer a call and see what he suggests. My 4110 is still under warranty.
On another note. That, as a dealer, you take enough interest to help so many is appreciated. Don't know that you guys hear that enough.
Thanks again
   / COLD STARTING #19
Just started my 2810 the other day at 2 degrees F and windchill of -10. I had to cycle the glow plugs 2 times but she started fine. I let her sit for @ 20 minutes to warm up and then only used her at 1/2 throttle for @ 45 minutes moving snow. No heating of any type, would like to get a heater for the block someday, but so far so good.
   / COLD STARTING #20
Not to question , But the manual for my mew 2615 said; "Do not run engine at lower idle in cold temps as the temp does not get into the warm range and engine damage could result..." even at 1800 rpm's, I'm barely in the green.
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2016 CATERPILLAR 272D2 WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
