3 Point hitch will not raise
   / 3 Point hitch will not raise #1
sidney
New Hampshire
Kubota/B7100 HST
My 3 point hitch will not raise my rear scraper blade on my B7100HST, front FEL works fine what gives any ideas?
   / 3 Point hitch will not raise #2
check and see if you have a flow control knob somewhere on the machine. It's used to control the speed of the 3pt lift arms. If it is slowed down to nothing you will have the problem you describe. I found that out on my BX.
   / 3 Point hitch will not raise #4
Agree with stump grinder as this just happened to me yesterday. I bought a new box blade yesterday and went to hook it up for the first time. My 3PH also would not lower until I realized that I slowed the flow control knob down too much after disconnecting my post hole digger last week. Not sure where your knob is located but a lot of them are located under the front side of the seat near the floor pan.
   / 3 Point hitch will not raise #5
I thought flow control on the 3pts only controls the lowering speed not the raise function?
   / 3 Point hitch will not raise #6
Will your 3pt not raise at all or only when the box blade is on it?
When you try to raise it do you hear it trying to do something, like pulling the engine down some/strain? Do you hear fluid moving when you try?
   / 3 Point hitch will not raise #7
I had that problem, one afternoon. I had to get that pile of mulch moved, so I removed the blade on the rear & continued to work. A couple hours later, I noticed it was working again.
In my case - I think it was dirt in the valve.
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2023 Ford Expedition SUV (A59231)
2023 Ford...
500BBL WHEELED...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56438)
2019 Krause...
