BURN BARREL BASE
   / BURN BARREL BASE #11
I use an old oil tank I cut in half. It works great. I can pick it up with the grapple and move it to empty the ash. It's nice how contained it is.
   / BURN BARREL BASE #12
I found that using a burn barrel with solid sides does not encourage incineration. So the last burn barrel I built was out of heavy duty 6 x 6 reinforcing sheet for concrete. Then I wrap it with turkey wire to keep the small stuff in and away it goes. Having the sides open promotes a hotter burn in less time with minimal after burn material.:D
   / BURN BARREL BASE #13
same hear, ive got some tight mesh fence that i use, like 1.5x3" holes.
i can smell my neighbors smoldering in there enclosed can for half of a day. mine is gone in an hr or less.
   / BURN BARREL BASE #14
LBrown59 said:
:confused:
*OK so now why is the pit any better than the barrel?
:confused:
I just saw your question. Sorry for the delay. Answer is the pit or overgrown hibachi, will burn quicker and a lower or less intense fire. If you burn firewood in it ,the fire could get too large,which would put the fire into a different category. Pit is elevated on legs and sits on a cement or other noncombustible base. plowking
   / BURN BARREL BASE #15
Back years ago when wife #1 and I got married we bought just a standard 55 gallon drum to burn trash in. Thought I would be smart and shoot holes in the bottom with her .25 automatic. Wound up with 3 slugs rolling around in the bottom of the drum with no holes. I did manage to put holes in it with the trusty 1911. :D
   / BURN BARREL BASE #16
When we built our house, used the cement truck clean out waste to pour a 3 by 3 base for 55 gal barrel to set on.
mark
   / BURN BARREL BASE
This burning barrel sets on end on top of the 2 metal bars spanning the cement blocks.
The problem I've encountered is the bars keep bending and sagging ; Yet the only weight on them is the light weight empty hollow drum.
The bars pictured are aluminum and didn't work out at all .
I replaced them with 3/4 steel pipe which was a big improvement but they are still starting to bend and sag.
Anybody got any ideas about what I could us for bars to prevent this?
BTW:the span between the blocks is only 54 inches.
   / BURN BARREL BASE #18
What is the easiest way to get the top off of a barrel? I have had some that were removable, but the one I have now is not.
   / BURN BARREL BASE #19
Drill a few 1/4 to 3/8 holes in a line. Hit a chissel/bar/screwdriver blade in the holes to tear out the "cross-connectors" between the holes. Then sawsall around the rim. You can get a pretty close cut that way.
Peter
   / BURN BARREL BASE #20
I have always used just a sharp cold chisel and a drilling hammer, the lip will pretty much guide the chisel and it will open up like a tin can. Wear heavy gloves because you will miss the chisel a couple times.
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A57192)
UNUSED IRANCH...
SET OF 60" SKID STEER QUICK ATTACH PALLET FORKS (A57192)
SET OF 60" SKID...
2009 Honda Pilot SUV (A55853)
2009 Honda Pilot...
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
2013 Peterbilt 367 (A55973)
2013 Peterbilt 367...
