OP
LBrown59
Super Star Member
- Joined
- Oct 27, 2004
- Messages
- 16,904
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
Always wear my safety goggles/ glasses when doing this !
I did this one with either a jig saw or a saws all.
either one will work but a saws all is quicker and easier.
If you're going to use the drum to burn in remove both ends like this one.
For the top end simply remove one of the caps/plugs and insert the saw blade through the hole and go to it.
No drilling chiseling hammering or hacking required.
For the bottom I drill one hole large enough to get A jig saw blade through and make a cut long enough to get the saws all blade through then switch from jig saw to saws all and finish it up.
Only one drilled hole and again no other drilling chiseling hammering or hacking required.
L B
Conservation said:What is the easiest way to get the top off of a barrel? I have had some that were removable, but the one I have now is not.
L B
