BURN BARREL BASE
   / BURN BARREL BASE #11
I use an old oil tank I cut in half. It works great. I can pick it up with the grapple and move it to empty the ash. It's nice how contained it is.
   / BURN BARREL BASE #12
I found that using a burn barrel with solid sides does not encourage incineration. So the last burn barrel I built was out of heavy duty 6 x 6 reinforcing sheet for concrete. Then I wrap it with turkey wire to keep the small stuff in and away it goes. Having the sides open promotes a hotter burn in less time with minimal after burn material.:D
   / BURN BARREL BASE #13
same hear, ive got some tight mesh fence that i use, like 1.5x3" holes.
i can smell my neighbors smoldering in there enclosed can for half of a day. mine is gone in an hr or less.
   / BURN BARREL BASE #14
LBrown59 said:
:confused:
*OK so now why is the pit any better than the barrel?
:confused:
I just saw your question. Sorry for the delay. Answer is the pit or overgrown hibachi, will burn quicker and a lower or less intense fire. If you burn firewood in it ,the fire could get too large,which would put the fire into a different category. Pit is elevated on legs and sits on a cement or other noncombustible base. plowking
   / BURN BARREL BASE #15
Back years ago when wife #1 and I got married we bought just a standard 55 gallon drum to burn trash in. Thought I would be smart and shoot holes in the bottom with her .25 automatic. Wound up with 3 slugs rolling around in the bottom of the drum with no holes. I did manage to put holes in it with the trusty 1911. :D
   / BURN BARREL BASE #16
When we built our house, used the cement truck clean out waste to pour a 3 by 3 base for 55 gal barrel to set on.
mark
   / BURN BARREL BASE
This burning barrel sets on end on top of the 2 metal bars spanning the cement blocks.
The problem I've encountered is the bars keep bending and sagging ; Yet the only weight on them is the light weight empty hollow drum.
The bars pictured are aluminum and didn't work out at all .
I replaced them with 3/4 steel pipe which was a big improvement but they are still starting to bend and sag.
Anybody got any ideas about what I could us for bars to prevent this?
BTW:the span between the blocks is only 54 inches.
   / BURN BARREL BASE #18
What is the easiest way to get the top off of a barrel? I have had some that were removable, but the one I have now is not.
   / BURN BARREL BASE #19
Drill a few 1/4 to 3/8 holes in a line. Hit a chissel/bar/screwdriver blade in the holes to tear out the "cross-connectors" between the holes. Then sawsall around the rim. You can get a pretty close cut that way.
Peter
   / BURN BARREL BASE #20
I have always used just a sharp cold chisel and a drilling hammer, the lip will pretty much guide the chisel and it will open up like a tin can. Wear heavy gloves because you will miss the chisel a couple times.
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A57193)
UNUSED RAYTREE...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
UNUSED FUTURE 12" CAT 305 EXCAVATOR BUCKET (A57193)
UNUSED FUTURE 12"...
UNUSED FUTURE FT-M48 48" HYD MIXING BUCKET (A57193)
UNUSED FUTURE...
John Deere 520M Loader (A53317)
John Deere 520M...
