DWCox
Does this same reasoning apply to synthetic hydraulic fluid as well? I am getting ready to swap out the hydraulic fluid and recently even bought five gallons of the JD hydraulic fluid (and filter) for which the JD is spec'd. I have noticed that if it is below freezing, my power steering is jerky and makes a bit of a noise until the fluid warms up considerably--which can take a while (this is after I have let the tractor engine warm up for five minutes or so at idle). This does not happen in warmer outside temps.
In other words, could I eliminate this factor as well by buying synthetic hydraulic fluid (four gallons at more than double the cost)?
Thanks.
Thanks.
