1964 ford 2000 row crop with wide front
   / 1964 ford 2000 row crop with wide front #1
tmanning
What's the ball park value on this tractor? 1964 2000. It has gas engine with no leaks. 4-speed transmission. No live power. Power steering. Hydraulics. Good paint. Starts easy and runs smooth. Row crop with wide front end. Tires could be better, but OK. Tractor has also been fitted with ROPS. Clean tractor. Not sure of hours.
   / 1964 ford 2000 row crop with wide front #2
Top dollar on average hours and condition about 4500 max!
   / 1964 ford 2000 row crop with wide front #3
You'd be hard pressed to get anything more than $3000 in this area.
   / 1964 ford 2000 row crop with wide front #4
That is going to be similar to a 741 ford.. actually.. if it had been a 7xx.. it'd likely be more valuable!
figure it pretty much like other hundred and early thousand series fords.. it's got the 134ci red tiger engine.. making it about 33hp.. etc.
decent 1500-4000 tops.
I bought a 951 pretty rough unit, narrow front ( single wheel ).. no sheet metal, needing tlc for 1500$.. and it has the 50hp engine like the 8xx/4000 4 cyl models..
now.. if it was an offset model.. might get you a lil premium..
soundguy
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
UNUSED FUTURE MINI SKID STEER HYD 12" AUGER (A51244)
UNUSED FUTURE MINI...
FUTURE SKID STEER QUICK ATTACH TRENCHER (A51243)
FUTURE SKID STEER...
UNUSED FUTURE MINI SKID STEER LAND LEVELER (A51244)
