What is the craziest build idea you ever had ?
   / What is the craziest build idea you ever had ? #51
We eventually went to a Cam-Lock fitting sold at TSC so you can load fast. The end of the barrel has been sharpened to "cut" the potatoe. The PVC barrel is also rifled.
   / What is the craziest build idea you ever had ? #52
I'd thought about the cam lock idea. The problem I have to overcome is how to make the potato cannon so I can load it from inside the turret but minimize the amount of cannon sticking into the tank. Any of these breech loaders I've seen have a pretty big butt sticking out behind the potato.
How did you rifle the PVC?
   / What is the craziest build idea you ever had ? #53
There's a guy on the Internet, shouldn't be hard to find him as he's the only one that I know that rifles PVC for barrels. He modified an old WWII machine to do the rifeling.
See them here
   / What is the craziest build idea you ever had ? #54
I built this tracked wheel barrow to get into my camp in the winter. After the intial test run I had to build a stiffer front Axle setup to keep the track from coming off and put an idler wheel on the chain to keep it from jumping teeth. It made about 7 (1300ft) trips to my camp. When I tried it in the spring I lost the quick link on the drive chain on some debris. Then I picked up an old Massey MF135 and have not returned to this project. FYI I placed a big wooden box on it to carry coolers etc.
YouTube - Tracked Wheelbarrow
   / What is the craziest build idea you ever had ? #55
So what did you use for tracks?
It looks like a handy little machine.
   / What is the craziest build idea you ever had ? #56
I had a piece of heavy 5" inch channel which I used as a die to press the track pieces. I then welded them to a chain. I made the front wheels adjustable to put tension on the tracks. I added an idler wheel linked to a contol on the handle to disengage the drive. While it operates nicely on snow, it is a bear to steer on solid ground with a couple hundred pounds on board.
   / What is the craziest build idea you ever had ? #57
found a couple of more pictures, including the plow I made to help it go through deep snow, made from cutting a fender.
   / What is the craziest build idea you ever had ? #58
Now that I have a snowblower, I may not need this thing anymore. I will reuse the parts though on some other project I am sure?
   / What is the craziest build idea you ever had ? #59
That "wheel barrow" looks awesome!
Shane
   / What is the craziest build idea you ever had ? #60
I've thought about fabricating my own track something like what you've done, but I was thinking about using roller chain. It sure seems like a lot of work. I'd need rubber pads on mine because I plan on using it on sidewalks and pavement in the summer.
Great project though. Thanks for posting. That really helps me to get ideas.
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A53422)
2009 Ford F-250...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
1667 (A57192)
1667 (A57192)
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
11' CONTAINER (A52706)
