TSC and Travellers Hydraulic Fluid
   / TSC and Travellers Hydraulic Fluid #1
GIJOE
Gold Member
Baton Rouge, La.
MAHINDRA 3510 w/ ML112 FEL
I was at TSC today looking at the Premium Universal Tractor Hydraulic Fluid. I stopped the store manager as he walked by and talked to him about the fluid. He told me the Travellers brand was made by Shell and relabeled for TSC. After I returned home I searched extensively on the web and could not find any info on that statement. Does anyone have other any info on this.
Joe
   / TSC and Travellers Hydraulic Fluid #2
Joe
I'm not sure, but, I would call "Travellers" and ask for the MSDS (Material Safety Data SHeet). I would then look at the MSDS for the manufacturer.
   / TSC and Travellers Hydraulic Fluid #3
I have used the MSDS to call the manufacturer to determine the fluids specification. I bought some hydraulic fluid locally for my NH. The MSDS allowed me to ask the manufacturer what specs the fluid met, not just guess.
Bob
I haven't been able to find any MSDS info on line about Travellers hydro fluids. Next time I'm at TSC I'll have to see if they have a copy.
Joe
   / TSC and Travellers Hydraulic Fluid #5
As others have said, get the MSDS info; and locations ARE supposed to keep copies on file since employees handle the stuff. Most places will not have loose leaf handouts, but a binder with the info which can be either viewed at location, or copied. The problem is with the minimum wage help, most don't know what they are, when updates/changes arrive in the manila envelope, they just get tossed somewhere, plus the chance of a store selling a very low toxicity product getting a surprise visit for compliance is slim to none. Did you check the small print on the bucket for a phone # or web site?. I bet the store manager is both right and wrong; when I bought my sliding barn door rollers there a while back, I looked over the Traveler line and it is a large product line, so Shell may make some of the products; probably antifreeze at least, and there may be several suppling other products in that line of products, which may or may not be the same at all parts of the country, nor all times of the year. I had heard Warren supplied some of the oil.
   / TSC and Travellers Hydraulic Fluid #6
I have a feeling that it is probably true its made by Shell. I use fluids sold by Rural King under the name of Harvest King and after some research I found out they were made by Citgo.
Chris
   / TSC and Travellers Hydraulic Fluid #8
Nice.. pretty much walmart supertech oil then.. only more expensive. glad i switched.
soundguy
   / TSC and Travellers Hydraulic Fluid #9
soundguy
Good thread--
I know nothing about WMT Supertech oils and such but am tempted each time I walk by. Is it worth a look?
   / TSC and Travellers Hydraulic Fluid #10
Supertech oil are great if you are not compared anything. They are cheap since they are cheaper oils.
   / TSC and Travellers Hydraulic Fluid #11
Good thread--
Considering I have two machines that take as much as 13g each of UTF oil per year.. plus 3 others that can take near 5g each.. then you look for a cheaper oil.
At about 20$ per 5g pail, who cars if the addative package only lasts 300 hours vs 600 hours compaired to the 50-60$ per 5g pails. I could theoretically change the oil 3x at the same price.. and thus have a cleaner sump.. but since I don't put 300 hrs on each machine.. I'm not running my add package out.. but yet I change the oils yearly to get rid of moisture.
soundguy
   / TSC and Travellers Hydraulic Fluid #12
soundguy
This is very interesting in that I put maybe 75 hours on each of my tractors per year and change the oil once a year. If the WMT oil is rated the same as other oil and I'm not putting the hours on the tractor, I'm beginning to think this may be a better way.
Even the WORST of the oil out there today is probably better than the best of 20 years ago and WMT stuff is not junk but probably a good product?
   / TSC and Travellers Hydraulic Fluid #13
Walmart oil is warren.. they are a pretty LARGE supplier.
I've been running the supertech oil in my 2002 NH 7610s since the 2nd year I've had it.. 1st year I used traveler TSC oil.. ( looks like it is warren oil too ).. Fast forward a couple years and NH oil is near 60$ for 5g.. and walmart oil is around 20ish$ for same... considdering I get less than a hundred hours on my high use machines when mowing.. I think it's safe to say the add package is still better than half there.. and I'm sure the tractor benefits from the sump cleaning...
With 5ys on that tractor on walmart oil now.. and no lube related failure,.. I think that is a quite positive sign. I did have a defect in a hyd valve pack repaired, but it was not lube related.. it was a bad pilot operated valve.. during the repair I asked them to check the rest of the hyd system out.. I figured if the walmart oil was damaging something.. it would show up... shop manager said the hyds were the best he'd seen in tractors in similar model lines.. all clean.. no sludge.. no apparrent wear.. pump met flow and pressure specs.. and relief was functioning at exact specs.
soundguy
   / TSC and Travellers Hydraulic Fluid #14
Quality oil has to do with the additive package, and then film surface scratch wear. Will the oil hold up under extreeme pressure. Just because you haven't experienced a gear train failure, doesn't mean that your gears, and related components aren't wearing more rapid with a qualified oil brand, but only minimumly qualified. The higher quality brands , especially the top brands, and synthetics are more resistance when the pressures get extreme, and the temperatures get hot. I use both also.:D
   / TSC and Travellers Hydraulic Fluid #15
Good post. Unless someone posts some UOA here, corn oil would work too...LOL
   / TSC and Travellers Hydraulic Fluid #16
You are forgetting that the oil in question meets or exceeds the ford M2C134 spec... does corn oil carry that rating?
soundguy
   / TSC and Travellers Hydraulic Fluid #17
Went to Walmart to buy Hydraulic Fluid and the ONLY fluid they carry is for jacks???
It was explained that not all Walmarts stock the same products...
So much for my second only visit to WM
   / TSC and Travellers Hydraulic Fluid #18
The first time I changed hyd oil in my JD, I used jd The second time I used TSC and the next time I will use JD. The TSC stuff whines and is sluggish in the cold. My experience.
   / TSC and Travellers Hydraulic Fluid #19
Did you ask for 'hydraulic oil'.. or for universal tractor fluid.
My local walmart does not stock 'hydraulic oil' either.. yet always has 4-5 5g pails of universal tractor fluid on the shelf.
soundguy
   / TSC and Travellers Hydraulic Fluid #20
A couple different manufacturers spec a different viscosity fluid for some applications.. like cold weather.. perhaps the UTF you bought from TSC did not meet the viscosity specs for the JD fluid you needed?
soundguy
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
(9) 55 GALLON METAL DRUMS (A60432)
(9) 55 GALLON...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
