I need somebody to confirm if this is indeed the fuel shutoff and if so then I'm at a loss....
I have no doubt it is the Fuel shutoff
"I wouldn't expect any, at least not out of the hole the solenoid was in"
I see I was assuming the Solenoid plunger was itself blocking the fuel path... By this statement I guess it actuates something that blocks the fuel path then?....
Yea a pump diagram would be very useful. If the solenoid actuates something, whatever it is could be stuck?
Is lever 1 spring loaded? Does it move when the solenoid actuates? It looks like if you removed the cap below lever 1 you would see the shutoff mechanism.. Although opening even this part of the pump may be something that should be considered carefully,
Hopefully the others with much more experience will chime in
yes, lever 1 is spring loaded...not a strong spring but when pulled forward it does retract back to it's original position quickly. I'm nearly positive the lever moves when the solenoid is activated as its presently in the "run" position.
