Prices Kubota JD Kioti 30+ HP which one is a good deal
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #21
Specific gravity of granite is about 2.75, so about 175# / ft^3.
That rock looks to be about 1'x1.5'x7' = 10.5 ft^3.
10.5 x 2.75 = 1840#.
I think you are looking at the Jersey barrier photo. The rock was about 2x2x3.5=14ft^ x175= 2450lbs
The loader had no real difficulty picking up the rock. The grapple held tight and what was amazing to me was that only one of the top tines actually was in contact with the rock. I didn't know that until I saw how big it was and decided to take a photo. If you look closely at the photo you can see air between the rock and the non engaged tine. Grapple survived but did get a slight flare in the tip of the upper tine. I figure it is a proud war wound.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #22
Wow! And that's way out in front of the loader. Is that the same grapple you had on the CK20?
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #23
Man that loader sure is a monster to be able to lift that rock and have the weight of the grapple and quick attach bracket.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #24
Yep, bought the grapple for my CK20 and just moved it to the new tractor. Millonzi 48 inch "Light Duty" :D. Cost me about $500 three years ago. :cool: Weight of the grapple per Millonzi was only 280 lbs but I have tried to push the thing around on the ground and I suspect it weighs more than that.
It works perfectly on the much more powerful KL401 loader (as seen in the photos) but was a great tool on my CK20 (avatar photo). A few encounters with rocks have given the upper tine tips a snaggletoothed look but it works just fine. Someday I'll heat those tips and get them back into position then reinforce them but otherwise the grapple is as solid as when I took delivery.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #25
When you compare loader ratings, watch where they're rated, don't know very many people that pick up rocks with their loader pins.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #26
Correct. But also be careful not to focus only on mid bucket lift ratings when you are not always lifting mid bucket loads. I find pivot pin comparisons between loaders the most accurate comparitor even if in the real world lift capacity is 80% or so. Bucket sizes and weights differ and don't tell you much about what you can lift with a grapple or forks for example. We rarely know the exact weight of our loads so lift capacities are more useful for comparing loaders rather than calculating real world performance.
Also, the companies only publish lift to full height which is a relatively rare occurance if you are lifting a maximum heavy load. We really need to know how much you can lift to 2ft (traveling height) or some similar standard but those data are never available for CUT loaders.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #27
Exactly, that's why I say, watch where they're rated, if you don't look at where they are rating the loader, the numbers can be confusing. In the heat of tractor shopping for a newbie, it's a detail that can be missed and a hungry salesman might not point out that little detail.
   / Prices Kubota JD Kioti 30+ HP which one is a good deal #28
Here's the numbers:
New L3240HST Tractor, hydrostatic drive, 4wd, diesel, folding rops, R4 industrial tires, tilt steering wheel, telescoping draft links, arm rests, open platform $16,119
New LA724 loader installed with quick-attach bracket, 72" quick-attach bucket, fluid in rear tires for ballast $4,808
New Landpride BB1572, 72" Boxscraper = $976
Total Package = $21,903
New Kubota L3400HST1-F Tractor, hydrostatic drive, 4wd, diesel,
folding rops, R4 industrial tires = $14,589
New LA463 loader installed with 60" pin-on bucket, fluid in rear tires for ballast = $3,917
New Landpride BB1560 60" boxscraper = $798 Total Package = $19,304
or Kioti DK35SE HST is a hydrostat transmission tractorwith Industrial tires and with a KL351 loader. The loader is good for 1412lb atthe pivot pins while the 3-point is rated at 2383lb 24 aft of the hitch. This tractor has a 38hp diesel engine and is loaded with features including 4x4shifting with locking differentials and is designed to be a top notch tractorwith a mid-level price. Price: $20,000 and has a $900 rebate available if a cash deal is made.
or
John Deere PRICE ON A 3032E (31.4HP) MFWD LOADER AND BOX SCRAPER
BE $16800.00.
Go for the Kubota 3240. Good tractors! That box blade price sounds kinda high though.
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A53473)
Adams Load Out...
Two Post Car Lift (A50120)
Two Post Car Lift...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2015 Tiger Trailers Inc. Gooseneck T/A Enclosed Trailer (A51692)
2015 Tiger...
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
