Kubota L35 Auxilary Hydraulics
   / Kubota L35 Auxilary Hydraulics #1
Keuka
I'm somewhat new to this site and not sure if this topic belongs here or in the hydraulics section. If I'm posted in the wrong area I apologize.
I recently picked up a real clean L35 (122 hrs) from an individual. Now that I'm hooked on the new toy, I'm thinking of implements and auxilary hydraulics. I e-mailed a dealer and found out that Kubota has a 3 spool kit available for around $1200 and valves will run around $220 a pop. Add hoses, quick connects etc., sounds like $1500-$2000 (less labor).
Questions:
1. Are there less expensive but equal quality after-market hydraulic parts available. Are the Kubota parts custom fit, higher quality and well worth the money?
2. If available, how's the fit and size of after-market compaired to Kubota? I've seen some do-it-yourself projects that worked but there were hoses and
valves everywhere.
3. Are there suppliers out there that will walk you through a project even if your not a professional.
4. Does this project require any pump adjustments or high tech. requirements better left to a dealer? I do most of my own equipment repairs and this project doesn't seem like rocket science but sometimes looks are deceiving.
I sure would like to see pictures of a finished project if anyone might have any. Thanks for any replies, great site and I'm sure I'll have more "beginner" questions.
   / Kubota L35 Auxilary Hydraulics #2
WR Long makes a 3rd function valve for auxilary front hydraulics, it is designed for a grapple, snow plow, etc. It will not run a snow Blower or a post hole digger. The cost was about $700 total, and I installed it myself, the kit is designed for do it yourselfers, and is relatively easy. I installed it on my B-26 to run my snow plow angle. I purchased the Valve from Carver Equipment. The Valve is electric over hydraulic, and is a true third function.
Search the Terms WR Long, and auxilary hydraulic valve, you should find some more answers. I tried to post some pics, but was having issues uploading them
   / Kubota L35 Auxilary Hydraulics #3
Are you talking about Auxillary Hydraulics for the front or rear?I have a Factory rear set very clean. I think I paid 1200 for 4 valves 2 sets.
At this point in time I'm looking for rear auxilary. I've never taken the backhoe off but it looks like when I do, I'll have two flexible lines. One preasure and one return. I assume after removing the hoe, I connect these two lines together.
I'm thinking of a hydraulic back blade or landscape rake with power right angle, power left angle and power tilt. Down the road I may look at a rear snow blower. Not knowing much, I'm thinking a three spool valve for the back blade.
I rechecked the figures the dealer e-mailed me and the Kubota Three Spool was around $1200 in hand. He said I would pay around $200 for single after market valves but he doesn't handle any.
After reading some of the posts it looks like Kubota has had problems with some of their valves so I assume, high quality after market may be less expensive and less trouble. I don't want to mix and match different types of hose connections.
The Kubota operators manual has little to no information on the hydraulics. Is there a web site where I might find info on the L35 hydraulic specs such as preasure settings, preasure limits, preasure relief valve locations and hose fitting type?
Thanks for you input.
   / Kubota L35 Auxilary Hydraulics #5
I know this is an old Post but can I get more details on your setup?
This is for the front...yes?
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2018 INTERNATIONAL LT SLEEPER (A52576)
2018 INTERNATIONAL...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
