Kubota L5740 3 Point hitch arm fall off
   / Kubota L5740 3 Point hitch arm fall off #11
Thanks bandit67.
I normally run the glow plugs for 10-30 seconds depending on the temperature. The tractor is stored inside a heated garage so it doesn't get really cold. I'll give it a few more tries. :D
Sorry for hijacking your thread chrissy28
   / Kubota L5740 3 Point hitch arm fall off #12
Thats also somewhat due to the emissions hardware. It takes more heat to get the engine running smoothly now. You'll find that with alot of equipment.
   / Kubota L5740 3 Point hitch arm fall off #13
Oh yeah, and the new ULSD fuel - much worse cold starts than the LSD fuel was.
Start up small puff of black smoke on both L5030 and L5740 then runs little rough 'til warms up then is fine.(1 minute?) Stored inside heated.
The glow plugs turn off automatically. As soon as light for glow plugs turns off I start up.
Are you blowing snow with the L5740? I find it is very powerful compared to L5030 has a little more power.
   / Kubota L5740 3 Point hitch arm fall off #15
Chrissy,
Do you have enough room to insert a small wire (tag wire comes to mind) in the holes of the snap ring to tie the snap ring in place ? It definitely sounds like the snap ring groove is either badly worn or perhaps was not cut deep enough. If it was mine, I would cut the groove deeper and install a smaller snap ring before spending money for a new shaft ( I'm cheap).
   / Kubota L5740 3 Point hitch arm fall off #16
chrissy28 said it's one year old so I think it should be warranty issue. I think until the parts come in chrissy28 was looking for ways to keep it on... personally ducktape comes to mind but I'm sure it's too cold for it to work so bailing wire is the next choice... :rolleyes:
   / Kubota L5740 3 Point hitch arm fall off #17
Yes we use it for snow removal. Its our first winter with it, and we're very pleased so far. We too find it strong. :) My father will be getting a bigger snowblower next year, as right now we're used the old snowblower that we had for the previous tractor (JD 1070, 40hp). What type and size snowblower are you using?
   / Kubota L5740 3 Point hitch arm fall off #18
Here it is with the arms attached.
So the upper arm is coming off the rock shaft. Snap rings have 2 sides and only one is correct. It could have been put on wrong (twice?) or the groove is too shallow or there may be a hunk of stuff in the groove. Next time it comes off, inspect it closely for debris. Put the snap ring in and make sure it seats all the way. And put it in the correct orientation.
jb
now 2011 and having same problem with snap rings breaking on my 3 point hitch.
Replaced shaft and few other parts in 2009.
There is a sway in the 3 point hitch with snow blower attached wondering if this is problem.
   / Kubota L5740 3 Point hitch arm fall off #20
Post more on this subject.... i have noticed a HUGE degredation is cold starts, only this year, with the NEW ag fuel my oil guy has foisted on me.....
even with additives, the stuff starts harder and stinks to high heaven........:mad:
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
Giyi  Land Leveler (A53316)
Giyi Land Leveler...
2015 Caterpillar 314E L CR (A53314)
2015 Caterpillar...
2016 Toro Greensmaster 3150 60in Reel Mower (A55787)
2016 Toro...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
