Rear brake locked up in cold. Is this OK?
/ Rear brake locked up in cold. Is this OK? #1
souliog
Looked at a 75 Yanmar ym240D last week and I want to buy it except the rear brake was locked up when I looked at it. We ended up breaking it free with the diff lock engaged. Afterwards the tractor ran out really well.
Should I run from this or is this acceptable in 20degree weather. Also the brake pedals will not return after engaing them. Feels like the return spring is too loose/stretched. The brake pedals will return to normal position if you assist them with your foot.
/ Rear brake locked up in cold. Is this OK? #2
If the right was locked up, you may well have broken the pinion gear in "freeing" it. It is not acceptable, and I would not touch it without making sure the right brake works. If it doesn't, it could be as simple as a broken brake shoe, or as complicated as a broken pinion gear. The tractor is powerful enough to snap this almost 1-1/4" thick piece of steel if the brake is solidly locked up (as in full of ice).
The differential lock was not intended to overcome a stuck or frozen brake, or to be engaged while one wheel is spinning. Using it in either situation creates a chance for peripheral damage.
/ Rear brake locked up in cold. Is this OK? #3
The shaft that goes through brake shoe cover is froze up, remove the cover and free up the shaft.
Danny
Did a few searches and I believe it is metal loose in the rear diff. I'm staying away. Thanks!
UNUSED X-STAR 250 GALLON FUEL TANK W/ FORK POCKETS (A60430)
UNUSED X-STAR 250...
2011 KUBOTA U25 SUPER SERIES EXCAVATOR (A60429)
2011 KUBOTA U25...
2008 KOBELCO SK210LC EXCAVATOR (A60429)
2008 KOBELCO...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2017 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2017 KOMATSU...
