Logging winch drive chain lube?
   / Logging winch drive chain lube? #1
BWSwede
Washington
Yanmar
I picked up a Farmi winch a month or so ago. It looks like I need to lub the drive chain. I understand that it is very important not to use just any ol' type of of oil or grease because it can run/seep down into the clutch, making it inoperable. I have looked at several hardware stores and motorcycle shops but I have not found anything that really stands out. So, what have you fellas with type of winch used to lube the chain?
Thanks in advance,
Blane
   / Logging winch drive chain lube? #2
I would have thought motorcycle chain lube would be perfect. I use it on my snowblower to good effect
   / Logging winch drive chain lube? #3
Ditto.. you can buy 'open chain and gear' lubes in a spray can.. real tacky stuff once the solvent evaps.
soundguy
Thanks for the input guys. I guess I was thinking that there was something out there better than motorcycle chain oil. I remember back in the day when I use to ride that I would get chain lube spattered under my fender. Maybe there are better formulas now.
Thanks again,
Blane
   / Logging winch drive chain lube? #5
You want sticky lube for a chain, I use it all the time....try chain saw chain lube it works really good and is really sticky too as it doesnt fling off real easy.
Craig
Is "sticky lube" a description or a brand name?
Thanks,
Blane
   / Logging winch drive chain lube? #7
If you hit a napa there is actually a can of " OPEN GEAR AND CHAIN LUBE "
soundguy
   / Logging winch drive chain lube? #8
Go to a motorcycle shop/dealer. Get a good grade of M/C chain lube. If your chain is an O-ring chain, they'll have a specific lube for them too. Most street bikers want a lube that stays put and doesn't end up on their chrome. Dirt bikers want a lube that defies dirt and water.
   / Logging winch drive chain lube? #9
Thanks,
Blane
Blane,
The term sticky lube is just a description. If you go and purchase any quality chain saw chain lube it will do you just fine in my opinion. Dont need to get fancy, just practical. A gallon will cost you about 5-7 bucks depending on where you buy it.
Craig
   / Logging winch drive chain lube? #10
I have a Farmi 3PH winch that I purchased new almost 30 years ago. On my winch there is one grease fitting for the bearing on the input shaft. About 5 years ago I took the winch apart just to check on things.
Everthing looked good. I have a spray can of "sticky grease" it was a Lubriplate product that is used for gears and sprockets that are open so I gave it a shot. Periodically I would spray WD-40 on the chain which I think helped without the worry of affecting the clutch. As I remember the drive chain and clutch are situated so that any grease or oil could not get from one to the other easily.
Randy
Set of AG R4 Wheels and Tires (A52128)
Set of AG R4...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
John Deere 1025R Tractor (A50514)
John Deere 1025R...
