wiring a 12v electric over hydraulic unit???
   / wiring a 12v electric over hydraulic unit???
these are picture details...working on getting pic url made...maybe 5 minutes if I have a connection
sorry...major connection problems with ISP...first time in 3 yrs - of course
The switch seems bonded into the plastic. In the picture switch is in center position and then up is up, down is down. Green wire is upper, black wire (hard to see) is middle) and white is the lower (aligned with down). Hopefully you can picture the rocker inside, I can't.
at the 3 socket plug the green, black and white transition to the following
green from switch harness goes to black wire into coil
black from switch harness goes to blue on solenoid
white from switch harness goes to green yellow wire on solenoid
sorry for the delay
http://img140.imageshack.us/img140/7718/switchak1.jpg
   / wiring a 12v electric over hydraulic unit??? #13
can you pull the switch out I need to see where the wires go on the back of the switch should have 6 terminals
1 2
3 4
5 6
and let me knowwhat the colors change to when they go through thepush conector I see you have green-black-white and on the other side towards the pump its green yellow-blue- black
I would plug the connector back together and check ohm readings from switch all the way to the other end with power off
   / wiring a 12v electric over hydraulic unit??? #14
jb889
I put a picture in your other post i just saw this one
tom
   / wiring a 12v electric over hydraulic unit??? #15
I just saw that print that's for a one way cyl he has a 2 way it's wired different
1 2
3 4
5 6
Sorry, but I should have been more clear. I can't get the switch out. It is bonded together. Believe me, I am good at getting things apart (but not back together). This thing seems thermally bonded as a unit front and back after taking off lock nut and lock ring.. In my other post I do identify how the wires change as they go through the connector. Here it is again.
at the 3 socket connector the green, black and white wires from the switch side transition to the following
   / wiring a 12v electric over hydraulic unit??? #17
I'd at least get some small starter cable for your pos/neg lead-in.
   / wiring a 12v electric over hydraulic unit??? #18
the unused port through the valve go's to the tank through the valve
sketch attached
tom
Have a question Will. What about the blue and the black wire (that seem to go nowhere) identified in my video? Were they part of a switch that disabled the handheld remote from inadvertant use?
I must be learning something because I could following your drawing really well. I don't fully understand everything but, hey it's not high voltage at least, right?!? LOL
   / wiring a 12v electric over hydraulic unit??? #20
can you put a meter on the wires on the back of the switch and tell me where the colors go to 1-2-3-4-5-6
the other thing IM concerned about is a broken wire around the switch usually they break right at the strain relief connector what I do is pull on each wire with a decent amount of pressure and you will see the insulation stretch ,from the first test you did told me that at least 2 of the wires are good but could be in wrong place
hyd valve motor solenoid
1 2
3------jumper----4-------feed
5 not used 6 jumper to2
FOR SOME REASON THE 1+2 are apart when I put it in but it shows 1+2 together when it post
1is hyd valve 2 is motor solenoid and 2 jumps to 6
VOLVO DD120B DBL DRUM ROLLER (A52707)
VOLVO DD120B DBL...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55314)
2012 NEW HOLLAND...
23018 (A55758)
23018 (A55758)
2022 Schulte 2500 Giant Rock Picker (A55314)
2022 Schulte 2500...
Mini Skidsteer Receiver (A55851)
Mini Skidsteer...
70pc 12ft.x 3ft. White Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
