Antifreeze mixture warning
   / Antifreeze mixture warning #1
Ford850
Super Member
Ohio
Case DX55, Ford 850
I heard this on the local weather the other night, and was shocked I had never heard it before. They warned viewers to never use more than a 50/50 mix of antifreeze. I've seen this on the antifreeze jugs many times, but always figured a stronger solution was bad for seals or something. What I didn't know was as the concentration goes above 50% or 60% the freeze point also rises. A 60% concentrated mix will protect down to -60 degrees, but 100% antifreeze will protect only to -10 degrees.
   / Antifreeze mixture warning #2
The information I read gives the freezing point of 100% ethelene glycol as 8 degree's F above zero .
   / Antifreeze mixture warning #3
I knew it.
   / Antifreeze mixture warning #4
What many people also do not realize is what effect the water has . The water is what carries the heat or at least the majority of the heat both away from the engine ( summer months ) and to the heater , ( in the winter months ) .
See it every year , people over heated in rest areas or on the side of the road and they cannot figure out why since they they had straight anti freeze in the car .:rolleyes:
Fred H.
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2012 LEEBOY 8515B ASPHALT PAVER (A51406)
2012 LEEBOY 8515B...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
