Driveway Make Over
   / Driveway Make Over #11
Will it ever pack? or stay loose? maybe after we get some of that stuff that falls from the sky...whatta call it? oh yeah -- rain.
The slag I bought last summer was under $3.75 a ton.
It's light compared to gravel or stone so it takes a lot more of it to make a ton.
A ton of it spread 4'' thick will will cover a lot larger sq foot area than a ton of stone or gravel spread 4'' deep.
You save 2 ways with the slag.
You get more of it per ton and a ton covers a bigger area.
A cubic yard of the ash weighs around 1900 lbs.
Yes it will pack down nicely after getting rain on it as well as driving on it too.
   / Driveway Make Over #15
LBrown, you ought to get yourself some of that pretty green slag they sell at the Magnessium Plant, South of Marietta. Where are you getting slag for $3.75 a ton?
Sincerely, Dirt
   / Driveway Make Over #18
This ash looks like great stuff and I thought the power plants had a hard time getting rid it. whish I had some coal fired plants near me.
   / Driveway Make Over #20
We paid $4.25 per ton for slag; plant is 10 miles away. I heard the same thing - it will not compact, and you still should get crush run on top, which will compact. I asked if you need the 4 inches of crush run that you normally do, in order to get enough depth to compact tightly and 'permanently' and I was told no, you didn't need as much. Maybe two inches of crush run. I'm not sure I believe that. I thought the compacting / 'locking' required 4 inches of the same type of material (crush run). So this slag seems to be a temporary repair kind of material - which we wanted. I'd still like to get crush run in the spring. The advice I've heard before, from here, is to have a compacted base before putting down crush run. So if this slag does not compact, how can I get a compacted base?
Pete
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2007 Utility 3000R 53ft T/A Reefer Trailer (A51692)
2007 Utility 3000R...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
