Driveway Make Over
/ Driveway Make Over #21
We paid $4.25 per ton for slag; plant is 10 miles away. I heard the same thing - it will not compact, and you still should get crush run on top, which will compact. I asked if you need the 4 inches of crush run that you normally do, in order to get enough depth to compact tightly and 'permanently' and I was told no, you didn't need as much. Maybe two inches of crush run. I'm not sure I believe that. I thought the compacting / 'locking' required 4 inches of the same type of material (crush run). So this slag seems to be a temporary repair kind of material - which we wanted. I'd still like to get crush run in the spring. The advice I've heard before, from here, is to have a compacted base before putting down crush run. So if this slag does not compact, how can I get a compacted base?
Pete
I just use slag and it compacts so there is no need for any other type of aggregate.
Slag is better simpler and cheaper for me.
/ Driveway Make Over #22
weedsport, all you need to do is top it off with crusher run slag. The crusher run slag will get hard once it gets a little moisture and gets run in with a vechicle.
Sincerely, Dirt
/ Driveway Make Over #23
Thanks Dirt, LBrown59,
I like the sound of that. I'll be compacting it in the spring.
Pete
Just curious if the slag or the ash pulverizes after a while?
What i got does not pulverize. It was run through a grinder at the bottom of the boiler before it is sent to the ash pit.
Will it ever pack? or stay loose? maybe after we get some of that stuff that falls from the sky...whatta call it? oh yeah -- rain.
Yes it has packed in really nice.:thumbsup:
2022 EZ-GO ELITE...
2018 PJ Trailers 14ft T/A End Dump Trailer (A61573)
2018 PJ Trailers...
2007 International 8600 Parts Truck (A63689)
2007 International...
2014 TAKEUCHI TB228 EXCAVATOR (A64279)
2014 TAKEUCHI...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
GE ENERGYSTAR WASHER & DRYER STACK (A64281)
GE ENERGYSTAR...
