Driveway Make Over
   / Driveway Make Over #11
Will it ever pack? or stay loose? maybe after we get some of that stuff that falls from the sky...whatta call it? oh yeah -- rain.
The slag I bought last summer was under $3.75 a ton.
It's light compared to gravel or stone so it takes a lot more of it to make a ton.
A ton of it spread 4'' thick will will cover a lot larger sq foot area than a ton of stone or gravel spread 4'' deep.
You save 2 ways with the slag.
You get more of it per ton and a ton covers a bigger area.
A cubic yard of the ash weighs around 1900 lbs.
Yes it will pack down nicely after getting rain on it as well as driving on it too.
   / Driveway Make Over #15
LBrown, you ought to get yourself some of that pretty green slag they sell at the Magnessium Plant, South of Marietta. Where are you getting slag for $3.75 a ton?
Sincerely, Dirt
   / Driveway Make Over #18
This ash looks like great stuff and I thought the power plants had a hard time getting rid it. whish I had some coal fired plants near me.
   / Driveway Make Over #20
We paid $4.25 per ton for slag; plant is 10 miles away. I heard the same thing - it will not compact, and you still should get crush run on top, which will compact. I asked if you need the 4 inches of crush run that you normally do, in order to get enough depth to compact tightly and 'permanently' and I was told no, you didn't need as much. Maybe two inches of crush run. I'm not sure I believe that. I thought the compacting / 'locking' required 4 inches of the same type of material (crush run). So this slag seems to be a temporary repair kind of material - which we wanted. I'd still like to get crush run in the spring. The advice I've heard before, from here, is to have a compacted base before putting down crush run. So if this slag does not compact, how can I get a compacted base?
Pete
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
1999 WABASH 48X102 FLATBED TRAILER (A53843)
1999 WABASH 48X102...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
